Front Disc Bolts - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 4 (permalink) Old 07-20-2011, 08:16 PM Thread Starter
Main Motorcycle: BMW K1600GTL
Other Motorcycle: T100
Front Disc Bolts
Anyone know the dimensions of the bolts holding the front discs?
Managed to part mangle the head of one when fitting new discs last weekend. Just took a look at World of Triumph to see how much they were.......I nearly wet myself!! Five quid for one bolt!! I know metal prices are high, cos the pikeys are now stealing drain covers, but that's just taking the p*ss!
robxxxx is offline
post #2 of 4 (permalink) Old 07-21-2011, 07:09 AM
Main Motorcycle: Tiger 1050 2007
No solution but know your pain! I had a similar problem with a sprocket bolt although not quite that pricey. At least I found a shouldered bolt at a bolt supplier to replace it.
DevilDog is offline
post #3 of 4 (permalink) Old 07-21-2011, 04:20 PM
Would'nt chance using any bolt, Brake discs work at very high temps and only high tensile steel bolts will do, Not worth it for a few ££, Just bit the bullet with a main agent Triumph part and call this a learning experience,
Good Luck
Spartan Andy is offline
post #4 of 4 (permalink) Old 07-22-2011, 08:16 PM
Good Luck
Andy, of course you are correct; however, that's why you don't buy bolts just anywhere. Bolts usually have a rating mark on the head or if you buy them from a place that specializes in bolts, they will tell you what you are getting. Don't remember what the front bolts look like but what made the rear special was its shoulder and it was an allen, not strength. That drives the price up because the manufacturing number is low. When I temporarily replaced my rear bolt, the bolt I got had a higher strength rating however it was a caps head, not an allen head. I just didn't feel like not riding for a couple months while that bolt got off Triumph back order.
DevilDog is offline
Floating Front Disc Kit Dickiedoodah Air Cooled Twins Technical Talk 18 01-05-2009 09:30 AM
stainless disc bolts? villageidiot T3 Sport / Touring Forum 1 10-10-2008 09:34 AM
Disc Brake Bolts colinm Air Cooled Twins Technical Talk 2 08-03-2008 01:50 AM
torque for bolts(front disc) buzbyman Air Cooled Twins Technical Talk 2 01-28-2008 04:01 PM
front disc-got one? rockinokie Air Cooled Twins Technical Talk 6 10-03-2007 02:43 PM
