Fuel leak from Steamer carbs - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 5 (permalink) Old 06-24-2011, 10:43 AM Thread Starter
Main Motorcycle: Daytona 1200 SE
Any advice on this one ?
Went to start my '97 Steamer, turned on petcock and has massive fuel leak from carbs / airbox. OK I thought - time to replace the 'o'-rings in the float bowls like I did on my '98 D12 last year. But the D12 has Mikuni carbs, the Steamer has Keihns. Is it likely to be a similar problem ( hardened 'o'-rings ) or should I check / replace abything else. I'll fit new float-bowl gaskets on re-assembly. Thanks in advance
tigerrider is offline
post #2 of 5 (permalink) Old 06-25-2011, 02:16 AM Thread Starter
Should have added that they are CVK carbs
post #3 of 5 (permalink) Old 06-25-2011, 04:38 AM
Main Motorcycle: tiger 1050
Sicking float ? Might just need freeing off. Just a suggestion before you go spending.
JJ
johnjo is offline
post #4 of 5 (permalink) Old 06-26-2011, 01:55 AM Thread Starter
Thx for reply JJ - Possibly. I cleaned out the float bowls ( not too bad ) operated the floats etc, reassembled and set the carbs upright on a bench. Topped up with fuel a funnel placed around the fuel feed, and no leaks!
I'll fit them back onto the bike and repeat with a greater head of pressure from the tank.
post #5 of 5 (permalink) Old 06-27-2011, 03:12 AM
Main Motorcycle: 2006 Tiger
miker's Avatar
Other Motorcycle: 1982 Harley "Sturgis"
Send a message via AIM to miker
My guess is that the needle valves were stuck with some gunge.... or, if they weren't gunged up, they are worn and will need replacing.
Mick
My Album
miker is offline
girlie versus steamer - why steamer is "better" in dirt? pizzaman383 Tiger Chat 6 02-02-2011 02:36 PM
Steamer fuel tank construction material gosling1 Tiger Workshop (archive) 5 03-28-2009 04:38 PM
Steamer Oil Leak tigerbill Tiger Workshop (archive) 4 09-30-2008 04:26 AM
Carbs Take a Leak mmead Hinckley Classic Triples 2 10-09-2007 12:22 PM
Gas leak from the carbs? PeeWee T3 Sport / Touring Forum 6 01-07-2005 05:41 PM
