Triumph Forum: Triumph Rat Motorcycle Forums (https://www.triumphrat.net/forum.php)
-   Tiger Mods & Bolt-Ons (archive) (https://www.triumphrat.net/tiger-mods-and-bolt-ons-archive/)
-   -   Tiger 855i Hagon Fork Springs 2" Shorter Than Standard? (https://www.triumphrat.net/tiger-mods-and-bolt-ons-archive/179845-tiger-855i-hagon-fork-springs-2-shorter-than-standard.html)
Biggerdave 07-11-2011 04:50 PM
Have just removed front forks on my 99 855i to fit Hagon progressive springs. A couple of questions 1) the Hagon's seem to be about 2" shorter than those fitted - is this normal? (yes I've checked the box and they are the right ones...) and 2) what weight oil i.e. 15 or 10 - I'm 270 lb so I guess the heavier weight would be a good bet?
Next step, fit the Hagon monoshock - but not until I've got the front end sorted first.
Thanks
Dave
Haggis 07-11-2011 06:43 PM
If the hagons are built to suit you I would presume that the weight of oil the manual recommends would be the one to use.
Did you get some metal (or plastic) pipe with your kit?
Cut the total length of new springs and pipe to match the springs and spacers (if any) you are taking out.
Biggerdave 07-12-2011 04:23 PM
Hi Haggis,
Thanks for the response - I actually spoke to Hagon today (nice guys) and they seem a bit confused themselves as to why they's changed the spec of the item themsleves in 2010! Previously their stock item was the same length as the OEM spring but the new item (and current stock listing) is definitely 45mm shorter. No, I didn't get any tubes with the kit, so I've just popped down to my local metal stockist and grabbed some off-cut pipe of the same OD to make longer spacers if that's the cure (as seems likely). I'll post how I get on and cheers again. Dave
Haggis 07-13-2011 12:53 AM
I'm sure some engineer somewhere has a reason. ;)
When I put in progressive fork springs in my bonnie they were shorter than the OEM, but the spacers (fancy word for pipe cut to suit) made up the difference. The bike runs tons better now than with stock.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
