Can in-tank fuel pump filter be cleaned? - Triumph Forum: Triumph Rat Motorcycle Forums
Tiger 800 - 800XC Mods & Workshop Workshop and technical talk for the 800 - 800XC Tourer - Adventurer Tigers
 3Likes
  • 2 Post By KildareMan
  • 1 Post By KildareMan
post #1 of 6 (permalink) Old 08-20-2019, 11:22 AM Thread Starter
Main Motorcycle: 2011 Speed Triple
Other Motorcycle: KTM 690, KTM 450xc
Extra Motorcycle: XR600R flat tracker
2012 800XC
I have the fuel pump out to replace the sending unit and wonder if it's possible to service the fuel pump filter since I have the assembly already out?
2011 Speed Triple, 1997 R1150RT, 2009 450 XCF
2008 690 E, 1996 XR600R, 2001 TTR-125L
Michelangelo is offline
post #2 of 6 (permalink) Old 08-20-2019, 12:21 PM
Main Motorcycle: 2012 Tiger 800 XC ABS
XYooper906's Avatar
Other Motorcycle: 2008 Husqvarna TE610
Extra Motorcycle: 1974 Kawasaki F11
Originally Posted by Michelangelo View Post
2012 800XC
They don't list the filter/strainer separately. It's inside the fuel pump assembly. But the filter is for sale on eBay. I would see how difficult it is to remove/reinstall it in the pump while you have it out.
XYooper906 is offline
post #3 of 6 (permalink) Old 08-28-2019, 09:42 AM
Main Motorcycle: Tiger 800 Venon Yellow
KildareMan's Avatar
There are 3rd party pumps available with removable filters to replace the triumph one. Way cheaper as well. Mine's nearly 9 years old and no issues.
Replacement pump:
https://www.highflowfuel.com/i-23899...2011-2019.html
CarlS and GearHd6 like this.
Venom Yellow
KildareMan is offline
post #4 of 6 (permalink) Old 08-31-2019, 11:11 AM
XYooper906's Avatar
Replacement pump:
Yes, this pump kit is cheaper than a triumph replacement pump. But the question was whether the filter can be serviced while the pump is removed to replace the sending unit.
If you can disassemble the OEM pump to get to the filter, there are replacement filters available for $15 on eBay. Cheaper still.
post #5 of 6 (permalink) Old 08-31-2019, 11:31 AM
KildareMan's Avatar
I mentioned the kit as the triumph pump/filter is not a serviceable item. Filter is permanently attached to pump. At least my 2011 is.
XYooper906 likes this.
post #6 of 6 (permalink) Old 08-31-2019, 04:51 PM
XYooper906's Avatar
I guess that what I am questioning is how the filter is attached to the motor/pump itself. In order to remove/install the motor/pump, you have to remove it from the white plastic housing, correct?
Are you saying that when you remove the motor/pump from the housing that the filter is permanently attached to the motor/pump itself? If it is, how do the new filters in the kit attach to the new motor/pump?
