16 XR - Fork Tube Replacement Alternatives - Triumph Forum: Triumph Rat Motorcycle Forums
Tiger 800 - 800XC Mods & Workshop Workshop and technical talk for the 800 - 800XC Tourer - Adventurer Tigers
 2Likes
  • 1 Post By GearHd6
  • 1 Post By Knightshade
post #1 of 8 (permalink) Old 04-25-2019, 02:16 PM Thread Starter
Main Motorcycle: 2016 Triumph Tiger 800 XR
Knightshade's Avatar
Other Motorcycle: 2008 Yamaha WR250X
Extra Motorcycle: 2008 Yamaha TTR125L
Hey there...so I decided that I needed new tires. Couldn't manage to get the front tire off..really odd. I suspected that there might be some cross threading going on, but decided to let the pros handle it. Took it to the shop where I bought the tires, and see if they could do anything w/it.
Yep..they couldn't get the damn thing out either. I'm looking at needing to hack the axle out of there, and replacing the left fork tube lower. (The black part where the front axle/spindle goes through.)
Well..wouldn't you know it. Triumph doesn't sell just the damn lower, I have to get a WHOLE NEW freeking fork tube, internals and all. To the tune of $741, because they can't sell me just the tube and associated lower w/o internals. An all or nothing kinda deal.
So..aside from hoping I can find something cheaper on ebay, is there a mfg who will replace the entire fork assembly w/improved internals?? Somebody please say yes...
"You live more for five minutes going fast on a bike like that than other people do in all of their life." - Marco Simoncelli
Knightshade is offline
post #2 of 8 (permalink) Old 04-26-2019, 11:03 AM
Main Motorcycle: 2015 Tiger 800 XCx
GearHd6's Avatar
Other Motorcycle: 1998 Daytona T595
It's sold separately. I see a T2048132 part number listed. I'm not sure which number is correct because I also see mention of a T2048171. But the part is available by itself.
https://www.triumphestore.com/p/Triu.../T2048132.html
CarlS likes this.
2015 Tiger 800 XCx
1998 Daytona T595
GearHd6 is offline
post #3 of 8 (permalink) Old 04-27-2019, 04:33 PM Thread Starter
Yeah, that isn’t the part I need. It is the black thing that isn’t labeled. The lower that part #22 (pinch bolts) is labeled to attach to in that diagram.
I found that Ohlins made complete forks for the previous gen Tiger. I also discovered that Racetech makes custom shocks too. Just not for the Tiger 800.
Lots of companies sell internals...nothing to be found on eBay at the moment.....
post #4 of 8 (permalink) Old 04-27-2019, 06:46 PM
GearHd6's Avatar
The black part the axle goes through isn't ever separate from the lower fork tube. You'd need the whole lower tube.
2015 Tiger 800 XCx
1998 Daytona T595
GearHd6 is offline
post #5 of 8 (permalink) Old 04-29-2019, 10:11 AM
Main Motorcycle: 2012 Tiger 800 XC ABS
XYooper906's Avatar
Other Motorcycle: 2008 Husqvarna TE610
Extra Motorcycle: 1974 Kawasaki F11
I would try one more time with something that applies more leverage. Apply some penetrating oil on the threads and let it soak overnight. A longer breaker bar might just do it. What do you have to lose at this point? Perhaps there is some corrosion or someone applied red locking compound. The red locking compound needs heat to release it, but I'd be very careful not to overheat the lower fitting.
XYooper906 is online now
post #6 of 8 (permalink) Old 04-29-2019, 11:41 PM
I would take a bolt same diameter as the axle. Grind the threads off. Grind an inch or so small enough to fit in. Drill a hole in a 2X4 so the axle can come through and shape it support the fork on the other side then whack the heck out of the bolt with a sledge hammer. If success move to step 2 if you fail Grind through the spacer and axle to get the wheel off. Remove the fork then just press it out.
Step 2 helicoil and a new axle and your done. Good investment would be decent threadlock on the helicoil!
VegasTigwr is offline
post #7 of 8 (permalink) Old 05-22-2019, 10:04 AM Thread Starter
I had a local shop do this exact thing. Well..not exact, but close enough. $270 in labor and about $80 in parts with a new axle and spacer. Mechanic believes previous owner had a mishap which bent the axle. All else checks out though, so that was great news.
Picked her up yesterday, now to get the new front shoe mounted!
CarlS likes this.
post #8 of 8 (permalink) Old 05-23-2019, 07:10 AM
Main Motorcycle: 2012 Triumph Tiger 800 XC
CarlS's Avatar
Other Motorcycle: 1968 Triumph Trophy TR6R
Extra Motorcycle: Honda Big Ruckus (SWMBO)
Glad you got it sorted.
Carl S
Old Soldier
CarlS is offline
Replacement Throttle Tube for T100 AlexB5892 Air Cooled Twins Talk 9 09-23-2017 04:33 AM
Stripped fork tube cap/HELP martinesmuffins Maintenance & Workshop Talk 2 10-26-2013 03:26 PM
How to install fork springs Retro-Racer Air Cooled Twins Technical Talk 7 05-26-2013 09:50 AM
BSA Fork Tube Help Snakeoil Classic, Vintage & Veteran 3 06-21-2011 09:09 PM
1050 fork seal replacement dieseltank Speed Triple Forum 1 03-18-2011 10:08 PM
