Tiger 800 wont start when engine is hot - Triumph Forum: Triumph Rat Motorcycle Forums
Tiger 800 - 800XC Mods & Workshop Workshop and technical talk for the 800 - 800XC Tourer - Adventurer Tigers
 33Likes
post #1 of 54 (permalink) Old 07-05-2018, 12:35 PM Thread Starter
Main Motorcycle: too hard to tell
Other Motorcycle: BMW K1200RS
Extra Motorcycle: Triumph Tiger 800XC
I have 2 videos showing a problem with my 2012 tiger 800XC that wont start it when engine is hot. The engine has a hard time turning over or that is how it sounds. I dont have the money to fix it in the shop as hey always seem to charge $1000.
The 1st shows how the tiger after about 1 hour of perfectly normal riding struggles to turn over the engine. At least that is how it sounds to me.
The 2nd shows the Tiger starting after 20 - 30 minutes cool down.
Ive got a new battery and problem still remains. Does anyone know what i should try to debug this? I have read about possible causes.
1. Sprag Clutch .. However i would expect the starter it not to struggle to a halt. I would expect the starter to keep turning and hearing some slipping noise as the sprag slips.
2. Bad battery. However this is a new battery.
3. Starter Motor .. One guy replied to my youtube post to say starter motor and he was on his 3rd starter motor.
4. Stepper motor for fuel mixture lever. This can get dirty from time to time and cause some starting problems.
Regards
pete
pete312 is offline
post #2 of 54 (permalink) Old 07-05-2018, 01:44 PM
Main Motorcycle: 2015 Tiger 800 XCx
GearHd6's Avatar
Other Motorcycle: 1998 Daytona T595
Sounds like the starter to me. Lots of them are known to go bad on those, especially the earlier years.
2015 Tiger 800 XCx
1998 Daytona T595
GearHd6 is offline
post #3 of 54 (permalink) Old 07-05-2018, 01:51 PM
Main Motorcycle: Tiger Sport
Other Motorcycle: Tiger 800 XRx
Extra Motorcycle: Ariel Huntmaster
Google it, there's loads with similar problem, some get cured, some don't.
Google this: triumph won't start when hot
Paul49 is offline
post #4 of 54 (permalink) Old 07-05-2018, 02:03 PM
Main Motorcycle: 1968 Bonneville T120R
68T120R's Avatar
Other Motorcycle: 2010 Jet Black T100
Extra Motorcycle: 2013 Black Tiger 800
I encounter this issue occasionally when my engine is hot... the engine will barely crank over and not enough to start. What I have discovered is, turning off the ignition and waiting for the stepper motor to shut down. You know the sound... sounds like a fax machine. After that, I can then start my Tiger normally.
Don't know if this is the issue you are having or if this will allow you to start your Tiger when it's hot, but it works for me.
Bob
Nulli Secundus
68T120R is offline
post #5 of 54 (permalink) Old 07-05-2018, 02:13 PM
GearHd6's Avatar
That hot start voltage is dropping way too low, there's obviously a serious voltage draw in that starter when it's hot.
XYooper906 likes this.
2015 Tiger 800 XCx
1998 Daytona T595
GearHd6 is offline
post #6 of 54 (permalink) Old 07-05-2018, 07:26 PM
tiny tiger's Avatar
I would pull the starter and take it apart and clean all the carbon off. Have you put a dc amp meter to see how many apps its pulling.
Sent from my SM-G930V using Tapatalk
electrons were excited to send you this!
tiny tiger is offline
post #7 of 54 (permalink) Old 07-06-2018, 02:40 AM Thread Starter
Thanks Guys
I will tackle this tomorrow and just clean the starter motor as Tiny Tiger suggested if the brushes look ok. I still don't clearly understand why heat would cause it to exhibit weak start but let it cool it will start. Heat does make resistance rise in materials so perhaps it's that simple.
I ordered parts here which sell in qty of 10 for $13 plus shipping. https://www.finditparts.com/products...so-028530-5312 Other than that site I could not find another source in USA. Pretty sad, don't you think?
Pete
tiny tiger likes this.
pete312 is offline
post #8 of 54 (permalink) Old 07-06-2018, 05:41 AM
GearHd6's Avatar
That's typical with a starter. Certain car starters are the same way, once it gets heat soaked it gets weak.
2015 Tiger 800 XCx
1998 Daytona T595
GearHd6 is offline
post #9 of 54 (permalink) Old 07-06-2018, 08:49 AM
Strange this happens with a small minority of our bikes. These same Denso starters used on other makes?
Paul49 is offline
post #10 of 54 (permalink) Old 07-06-2018, 12:05 PM
Main Motorcycle: 14 Tiger 800 ABS
teamcurtis's Avatar
Other Motorcycle: 03 Sportster Scrambler
This helps explain why.... (assuming it actually is heat soak)
https://www.knowyourparts.com/techni...hot-heat-soak/
CarlS, pete312 and strick909 like this.
I like motorcycles
teamcurtis is offline
No start when bike is hot Run Sprint Run Sprint Forum 4 04-29-2018 08:56 AM
From 2016 Street Triple R to Tiger 800 XRT :) MotoChooch Tiger Chat 31 07-05-2017 08:52 AM
BMW F800GT Vs Triumph Tiger 800. Initial Thoughts SVguy Tiger Chat 19 07-12-2015 08:59 PM
1962 Tiger with unit engine? grumman41 Classic, Vintage & Veteran 5 05-20-2015 08:24 PM
855 engine into a 2001 Tiger?? Derswede Tiger's 885i & 955i - Mods & Workshop 1 05-02-2015 12:59 PM
