Turn Signal relay for LEDs? - Triumph Forum: Triumph Rat Motorcycle Forums
Tiger 800 - 800XC Mods & Workshop Workshop and technical talk for the 800 - 800XC Tourer - Adventurer Tigers
 9Likes
post #1 of 27 (permalink) Old 10-15-2017, 08:57 PM Thread Starter
Main Motorcycle: Sprint ST
Other Motorcycle: Tiger 800XCA
Extra Motorcycle: DR650
What are you guys using for the relay for LED turn signals? I broke one of my front signals last weekend and I have a set of nice looking LEDs that have been in my bike parts tub for about two years that I want to use.
Thanks.
2017 Triumph Tiger 800XCA
2017 Kawasaki Versys-X 300
2004 Triumph Sprint ST 955i
1996 Suzuki DR650
RobGADV is offline
post #2 of 27 (permalink) Old 10-16-2017, 05:39 AM
Main Motorcycle: 2015 Tiger 800 XCx
GearHd6's Avatar
Other Motorcycle: 1998 Daytona T595
I could be wrong but I don't think you need anything special to put LED's on the new generation bike because they no longer have an external flasher, it's now built into the computer.
2015 Tiger 800 XCx
1998 Daytona T595
GearHd6 is offline
post #3 of 27 (permalink) Old 11-03-2017, 06:32 PM Thread Starter
I just put one LED signal on my Tiger to replace the broken one, and nope, it needs a relay. It's fast-blinking.
1996 Suzuki DR650
RobGADV is offline
post #4 of 27 (permalink) Old 11-04-2017, 08:32 AM
Main Motorcycle: 2012 Tiger 800 XC ABS
XYooper906's Avatar
Other Motorcycle: 2008 Husqvarna TE610
Extra Motorcycle: 1974 Kawasaki F11
Thanks.
On my 2012, I used a Novita EP34 flasher when I converted it to LED signals. It has an extra terminal marked "E" that goes to ground. "L" and "B" go to their respective wires that they went to on the original flasher.
Not sure if it's relevant to your XCA.
CarlS likes this.
XYooper906 is online now
post #5 of 27 (permalink) Old 02-07-2018, 08:51 AM
Mulepick's Avatar
I just put a post in on this and will remove it if I can get some answers here. My 16's turn signals are apparently run by the computer now and LEDs still blink fast. I guess the only option is resistors at each turn signal?
Bob
2016 Triumph Tiger 800 XCx
2018 BMW K1600B
2016 Yamaha TW-200
Rokon Trailbreaker
Mulepick is offline
post #6 of 27 (permalink) Old 02-07-2018, 11:44 AM
XYooper906's Avatar
Bob
The reason resistors are used on older bikes are due to the resistance type of flasher units, to mimic the resistance of a conventional bulb since the LED bulbs provide very little. (Or you can use an LED-compatible electronic flasher without adding resistors).
Knowing that, I doubt that adding a resistor would do anything to affect the flash rate, if the lights are truly flashed by the computer on the newer bikes. Unless the lights are just controlled on/off by the computer, and flashed with a conventional flasher. Has anyone confirmed whether a flasher exists on the newer bikes?
post #7 of 27 (permalink) Old 02-08-2018, 01:43 AM
Mulepick's Avatar
The manual only shows the location of the flasher on the xc not the xcx or xcr. This function is presumably handled by the computer now and the computer on my '16 is not prepared for LED swaps. I like at least one other will have to live with the double flash.
2018 BMW K1600B
2016 Yamaha TW-200
Rokon Trailbreaker
Mulepick is offline
post #8 of 27 (permalink) Old 03-17-2018, 11:45 PM
interactive3's Avatar
Other Motorcycle: 2003 KLX400SR
Iím working on my 2015 Tiger XCx. I removed the incandescent front turn signals and mounted some nice bright LED signals with 25W 8 ohm resistors in parallel. I tested the operation with the ignition on (engine off) and the new system worked perfectly, blinking at a regular rate. I buttoned everything up started the engine and there is no turn signal illumination with the engine running.
I have the stock rear signals.
Anyone know what the issue is? Do I need a different resistor value, or no resistors at all up front? I want to keep the auto cancelling turn signal feature. Thank you.
interactive3 is online now
post #9 of 27 (permalink) Old 03-18-2018, 11:47 AM
Main Motorcycle: All
pmorritt's Avatar
Other Motorcycle: one at a time
If you have an ďIĒ button on your controls you donít need a resistor.
Masquerading every day as a normal person is exhausting.
pmorritt is online now
post #10 of 27 (permalink) Old 03-18-2018, 11:54 AM
Thank you.
Iím going to try no resistor and then a 6 ohm to see which might work. My motorcycle is not local so I have to prepare wiring and connectors at home and then try them on the motorcycle.
Sent from my iPhone using Tapatalk
Turn signal + dash indicator issue (possibly relay related)? bushmat4 Air Cooled Twins Technical Talk 4 08-08-2017 08:24 PM
Sanity check - turn signal wiring on '79 T140E bhart356 Classic, Vintage & Veteran 4 08-17-2016 07:12 PM
Indicator (turn signal) flasher relay on Tiger 995i ?? Rev-O Tiger Chat 4 06-01-2016 01:26 PM
Turn Signal Relay Estuans T3 Sport / Touring Forum 3 09-16-2015 02:35 PM
Question on upgrading turn signal relay joeysan Air Cooled Twins Technical Talk 1 08-28-2015 03:18 AM
