Convert Turn Signal Lights to Bright LEDs With NO Resistor Needed - Triumph Forum: Triumph Rat Motorcycle Forums
Tiger 1200 - Mods & Workshop Workshop and technical talk for the 1200 Tiger Explorer
post #1 of 7 (permalink) Old 05-17-2019, 07:44 PM Thread Starter
Main Motorcycle: 2018 Tiger 1200 XRT
xBandit's Avatar
Other Motorcycle: 2013 Yamaha FJR1300
Extra Motorcycle: 2006 Yamaha R1
Somewhere on the internet I saw someone post they found an LED bulb that will replace the Triumph factory OEM signal bulb and not need resistors installed to maintain regular flash rate. I could not find that post after a bunch of searching. I tried it – it works GREAT! So here’s the info.
The stock turn signals have 12 Volt / 10 Watt amber bulbs which go by 584332 with Base Type BAU15S (Bayonet Single Contact (SC) with 30º studs offset. Outside of UK, these are not easy to find. They are also among the dimmest signal light bulbs on any modern motor vehicle.
Usually, when replacing incandescent (filament) bulbs with LEDs either the flash rate gets much faster or the instruments show a lighting error (CANBUS equipped).
The only AMBER LED bulb I could find that is CANBUS compatible (will not need resistors and will not throw an error code on your dash) AND fit inside the Triumph signal housings are these:
https://www.amazon.com/AJUMKER-Extre...r=8-1-fkmrnull
https://www.amazon.ca/dp/B07H9KN2W5/...800_TE_3p_dp_1
https://www.amazon.co.uk/AJUMKER-Ext...Y0SKZDNSSRQT1H
ATTACHED is a PDF document I made with full details and instructions. Enjoy!
File Type: pdf Triumph Tiger LED Turn Signals Bulbs.pdf (194.1 KB, 78 views)
If it doesn't have at least 3 cylinders and 1 litre, forget it!
xBandit is offline
post #2 of 7 (permalink) Old 05-17-2019, 08:29 PM
Main Motorcycle: 2003 Thunderbird Sport
Mikerunsjax's Avatar
Other Motorcycle: 2007 Triumph Speedmaster
Extra Motorcycle: 2012 Harley Fat Boy Lo
I changed the signals on my Speedmaster to something a little smaller. I like the looks, but they’re not as bright s I’d like. If they have bulbs that fit mine, it would be a great option.
Thanks for the info. I’ll research further for mine.
Mike
Jax Fl.
2007 Speedmaster
2012 Fat Boy Lo
Mikerunsjax is online now
post #3 of 7 (permalink) Old 05-22-2019, 12:12 AM
Main Motorcycle: 2016 Tiger 800 XCxR
troop's Avatar
Other Motorcycle: 2009 H-D FLHT
Did you install these bulbs at all four corners or only to the front or rear ? Wondering if flash rate is fine for two bulbs but might be rapid with four bulbs? I'd be happy with the brighter turn lights to the rear. I already have LED headlight bulbs and (2) sets of LED aux lights installed on the front.
troop is offline
post #4 of 7 (permalink) Old 05-22-2019, 03:31 AM Thread Starter
xBandit's Avatar
I tried the front right bulb on its own first: fine. Then front left: Fine. Then the rear two, one at a time, and all was well. However, if you have low-draw LEDs in the front already, when you switch the rear two, there is a 'small' chance things might not work out, but since these LEDs draw similar to incandescents, likely not a problem. I know that's a bit convoluted, but hope that helps. I'd try it if I was you - high chance of success.
xBandit is offline
post #5 of 7 (permalink) Old 05-22-2019, 10:56 AM
troop's Avatar
OK.. Thanks you. I'll first order a pair for the rear and see how they go.
troop is offline
post #6 of 7 (permalink) Old 06-11-2019, 04:17 PM
troop's Avatar
Got mine today, and, no go..
1.) Too long for 800 directional housing
2.) Hyper flash
3. MUCH brighter
Will sell a pair for $11/mailed lower 48. Save $5 and couple/few weeks delivery time...
troop is offline
post #7 of 7 (permalink) Old 06-12-2019, 02:21 AM Thread Starter
xBandit's Avatar
[QUOTE=troop;2003948240]Got mine today, and, no go..
2.) Hyper flash
3. MUCH brighter
That's too bad. Yeah, I didn't think they would fit in the 800 - appears to have different design signal lights. And if you don't have the model with the colour TFT screen, you have an old-style relay that would hyper-flash (easy to replace with a true electronic relay that would always flash right). And yes, they are MUCH brighter.
xBandit is offline
Dual LED turn signals - brake light overriding turn signal kevseymour Air Cooled Twins Talk 0 04-30-2018 06:21 PM
Connecting 2 Set of Turn Signal to stock turn signal wiring jayanusham Air Cooled Cruisers - America, Speedmaster 1 04-02-2018 08:31 AM
New additional turn signal indicator lamp (led) David Eye Air Cooled Twins Technical Talk 12 03-06-2016 03:58 PM
Yet another turn signal question. GTO Bruin Air Cooled Twins Technical Talk 13 10-08-2012 01:12 AM
Turn signal dash lights Azzdude T3 Sport / Touring Forum 0 10-21-2007 06:30 PM
