Swap Aux Power Sockets: Front-Rear (?) - Triumph Forum: Triumph Rat Motorcycle Forums
Tiger 1200 - Mods & Workshop Workshop and technical talk for the 1200 Tiger Explorer
post #1 of 3 (permalink) Old 05-16-2019, 03:41 PM Thread Starter
Main Motorcycle: 2018 Tiger 1200 XRT
xBandit's Avatar
Other Motorcycle: 2013 Yamaha FJR1300
Extra Motorcycle: 2006 Yamaha R1
Question Swap Aux Power Sockets: Front-Rear (?)
Sorry if the answer is already here somewhere, but I have done a ton of searching and can't find this particular thing about Aux Power Sockets.
i have 2018 Tiger 1200 XRT with factory DIN/Powerlet sockets at front of fuel tank and on left rear. The front one is direct to battery and the rear is ignition switched. I need that reversed (front socket switched, rear socket direct to battery). It is to power my GPS unit, which really works best off switched power.
Does anyone know if this is a simple matter of swapping over connectors somewhere, or are these sockets wired deep into the main harness? I have looked through the online service manual and could not find any detail on the wiring routing for these two sockets.
OR.... is there an available connector source of switched power in the front of the bike somewhere? I try to avoid splicing/tapping into wires and prefer to buy connectors for nice plug-and-play solutions.
Thanks.
If it doesn't have at least 3 cylinders and 1 litre, forget it!
xBandit is offline
post #2 of 3 (permalink) Old 05-17-2019, 04:18 PM
Main Motorcycle: 2015 Tiger 800 XCx
GearHd6's Avatar
Other Motorcycle: 1998 Daytona T595
I hardwired mine into the load side of the auxiliary lights fuse. Might be something to consider. I pulled the terminal out of the fuse box and soldered the GPS wire right to it so I didn't have any bad splices later.
2015 Tiger 800 XCx
1998 Daytona T595
GearHd6 is offline
post #3 of 3 (permalink) Old 07-07-2019, 05:44 AM
Newbie
Main Motorcycle: 2014 Tiger Explorer
Rockhopp3r's Avatar
Have you considered a fuse block of some sort? I have a Fuzeblock and it allows me to select constant or switched power for every circuit. You do have to tap into a wire if you want to use switched. I use all of mine constant, so didn't need to.
Rockhopp3r is offline
Rounded brake pad retaining pin Lewishamilton Water Cooled Twins Talk 2 03-11-2019 07:32 AM
Torque Setting List zucchina Water Cooled Twins Talk 4 05-10-2017 11:09 PM
Possible GSXR front end swap magrahamkp08 Club Cafe' 10 09-26-2011 01:56 PM
Bitubo front and rear suspension on a Thrux NorthernThrux Air Cooled Twins Technical Talk 5 08-22-2011 08:19 AM
Suspension Setup - Step by Step Sparti Speed Triple Forum 11 05-28-2006 02:33 AM
