1200 Explorer Heat from engine - Triumph Forum: Triumph Rat Motorcycle Forums
Tiger 1200 - Mods & Workshop Workshop and technical talk for the 1200 Tiger Explorer
post #1 of 38 (permalink) Old 07-04-2017, 12:42 AM Thread Starter
Main Motorcycle: 2017 Triumph Explorer XCA
Kislo's Avatar
Other Motorcycle: 1974 Norton Commando 850
HI All, Proud owner of a 2017 Explorer XCA. SO far all I expected with the exception of one thing!!! Does anyone else have a heat issues on the family jewels from the engine?? Here in Alberta I went riding the other day, it was approx 30C and wow was it hot on the boys!!! Anything anyone is doing or has done to divert the heat??
Kislo is offline
post #2 of 38 (permalink) Old 07-04-2017, 08:51 PM
Main Motorcycle: 2017 Explorer XRt
fredrider's Avatar
Other Motorcycle: 2009 Suzuki V-Strom DL650
Kislo,
I bought a 2017 XRt in January, and have the same question as you do. I have not seen any solutions to the heat on Triumphs with either the 800cc or 1200cc engines. Unlike Honda and Yamaha, with their ST1300 and FJR1300 sport-tourers, where the OEM's diverted hot engine air and also used some heat shielding, it does not appear that Triumph has done anywhere near enough to keep engine heat away from the rider's crotch, thighs or calves. What I have been doing is sitting further back in the saddle as far away from the crotch heat as possible and also wearing perforated riding boots as well as mesh pants. It would be nice if there was other alternatives.
Fred
fredrider is offline
post #3 of 38 (permalink) Old 07-06-2017, 01:05 AM Thread Starter
Kislo's Avatar
Thanks Fred. I am not getting it on the lower legs as much, but definitely the crotch on temps above 25C. I am going to bring it up with the dealer this weekend and see what they suggest. If I find anything out I will pass along. Ride safe!!!!
Kislo is offline
post #4 of 38 (permalink) Old 07-07-2017, 05:18 PM
joeschmoe's Avatar
I wonder if a person could put some heat resistant material under the tank/seat to disperse the heat? I have seen similar material inside guitar amplifiers and inside cars that perform that function.
joeschmoe is offline
post #5 of 38 (permalink) Old 07-07-2017, 10:15 PM
fredrider's Avatar
I was wondering the same thing. When Honda first came out with the ST1300 and about the same time Yamaha came out with the FJR1300, I demoed both of them, and they did have a lot of hot air blowing on the rider's legs. Some of the owners started finding remedies and I believe that the OEMs redirected some of the hot air flow and also adopted the heat shield remedies the owners were using. I hope that Triumph does the same.
Fred
post #6 of 38 (permalink) Old 07-08-2017, 11:21 AM
Main Motorcycle: Tiger Explorer
lobout's Avatar
Other Motorcycle: Honda 300
I have a 2014 XC and it's the same. I believe Triumph tweaked things and the new models are better, but clearly it hasn't made a huge difference.
lobout is offline
post #7 of 38 (permalink) Old 07-08-2017, 03:02 PM
fredrider's Avatar
It does appears that Triumph has tried to re-distribute the air flow by providing an airflow channel right next to each side of the radiator, as shown below in black just right of the Explorer XRt.
This added airflow channel may help a little, but there is still significant heat flowing onto my boots, calves, thighs and groin.
Fred
post #8 of 38 (permalink) Old 07-09-2017, 05:56 AM
Main Motorcycle: Triumph Explorer XCA
I've got a three month old XCA and if anything my bollocks are hotter than on the old model I had. Great in winter, less so in summer despite wearing trousers with vents in them. Would be interested in any solutions.
Sent from my iPad using Tapatalk
Wilko1202 is offline
post #9 of 38 (permalink) Old 07-14-2017, 04:45 PM
HAP
Main Motorcycle: 2013 explorer
Other Motorcycle: a few
Extra Motorcycle: a couple
Every 3 cylinder Triumphs I have had from the 95 Trident to the Explorer has had uncomfortable heat on my privates.
I learned to put the foil covered sticky foam on the bottom of the seats which helped a lot except on the 09 ST. Had to sell it as the lady of the house refused to ride it any more. Hot butt she said was not her idea of touring.
HAP is offline
post #10 of 38 (permalink) Old 07-19-2017, 10:34 AM
joeschmoe's Avatar
I was giving this some more thought. Has anyone considered having the headers coated by jet hot? I called them out of curiosity and was quoted a bit less than $250 for standard colors and right at $250 for other colors. Only the outside would be coated due to the cat inside the header system. 30% to 40% reduction in heat.
The argument could be made that why would some one need/want to do this to their new $19k motorcycle. I know I have read that not everyone has experienced the heat issue, but for those of you who have, this may be a viable option.
Engine missing while riding RICHW Air Cooled Twins Technical Talk 39 09-04-2019 04:47 PM
o1marc's 1970 Tiger 650 o1marc Member's Restoration & Rebuild Projects 1041 07-21-2018 06:15 AM
Trolley Engine Starter Steve Leeson Daytona Deliberations 8 04-27-2016 07:18 AM
