Battery issues - maybe?? - Triumph Forum: Triumph Rat Motorcycle Forums
Tiger 1050 - Mods & Workshop Workshop and technical talk for the 1050 Tiger
 2Likes
post #1 of 15 (permalink) Old 11-03-2018, 02:14 PM Thread Starter
Main Motorcycle: Tiger 1050
GavinD's Avatar
Noobie Question.
Have a tiger 1050 2009, which is started exhibiting issues with re-starting after recent stops. E.g. park up to check phone....then did not restart.
A half-hearted cough and nothing.....however leave for 20 minutes would start.
Suggestion was "duff" battery, which was duly replaced and all seemed good for the next week.
Then it started doing it again.
Bought an Oxford battery charger / manager and when checking the battery does seem to be holding a charge.
a) what should I be looking for?
b) portable charger (for backup), any recommendations?
Thanks.
GavinD is offline
post #2 of 15 (permalink) Old 11-03-2018, 04:58 PM
Main Motorcycle: Bonneville SE EFI 2011
Lpar's Avatar
I wouldn't know about a portable battery charger, but to keep an eye on the battery (and alternator) I find the Gammatronix monitor invaluable. It's inexpensive yet very well made both software and hardware.
Link here.
(I have no business with these folks just a happy customer!!).
TORs, SAI/O2/snorkel removed, TTP Airbox Cover w/DNA filter, TTP Tune#1, Triumph windshields, G2 Throttle Tamer, NH Low-UK bar, SW-Motech Footpegs, Gammatronix Battery Monitor, Triumph handguards, Oxford heated grips, Denali SoundBomb + more ;)
Lpar is online now
post #3 of 15 (permalink) Old 11-03-2018, 06:26 PM Thread Starter
GavinD's Avatar
Thankx
Looking on-line at one now.
GavinD is offline
post #4 of 15 (permalink) Old 04-01-2019, 01:30 PM Thread Starter
GavinD's Avatar
Got a portable charger...FAB solution - all be it a "get out of jail".
Still trying to get to the bottom of why, battery is not charging (quickly??), as I have been told - there is a charge reaching the battery.
As this is a recent thing. And have changed battery (now on second replacement).
I suspect there is something more fundamental going on here.
Any ideas? Gratefully received.
GavinD is offline
post #5 of 15 (permalink) Old 04-01-2019, 04:19 PM
Main Motorcycle: '98 T595 Daytona
Other Motorcycle: 2014 Ninja 1000ABS
You need to check the charging system of the bike. Your portable charger is not the answer. There are many threads on checking the charging system. Basically, charge the battery overnight so it has a full charge. Start the bike and let warm up a bit to go off fast idle and onto regular idle rpm. Check the battery voltage at idle and then maybe at 3-4Krpm. You should see 13+VDC at idle and up to 14VDC at the higher rpm. If not, then it could be the R/R or the connector from the stator to the R/R or even the stator. To check the stator, unplug the connector to the R/R, then using your meter set to Ohms, resistance, the red probe of the meter on one of the three stator pins in the connector and the black probe to battery ground. There should be zero continuity or infinite resistance, an open circuit. The stator should not be grounded. You are checking the pins on the stator side of the connector, not the R/R side.
How much charge is reaching the battery is crucial. Who told you about the charge reaching the battery? Did a mechanic test the charging system for you?
Felony is online now
post #6 of 15 (permalink) Old 04-03-2019, 08:53 PM
Main Motorcycle: 07 Triumph Tiger 1050
Cloudy's Avatar
Extra Motorcycle: Triumph Bonneville se '13
A common problem of not starting after having been run is apparently when warm the battery leads aren't up to the job of carrying the load required to start the bike. There's a guy on the facebook page that make's upgraded cable's and by all accounts it cure's the problem. https://www.facebook.com/groups/8304...31369/?fref=nf
07 Tiger 1050,K&N Filter,Snorkel Removed,Storm GP Exhaust,20550 Frankentune Map,NGK Iridium Plugs,Ricks R/R,Ohlins Rear Shock,Ohlins Front Springs,Bar End Mirrors,LED Spots,Leather Seat Cover,Ebay Levers,Ebay Risers,Custom Bars.
Cloudy is offline
post #7 of 15 (permalink) Old 04-08-2019, 05:17 AM
Main Motorcycle: Tiger Sport
Other Motorcycle: Daytona 900
Check the battery type. Triumph upgraded Tiger battery to YTX14-BS around that time. Earlier battery type were too weak, especially if there is an alarm fitted. I had the same woes and an upgraded fixed it.
Paul
PaulRayBerg is offline
post #8 of 15 (permalink) Old 04-19-2019, 10:42 AM Thread Starter
GavinD's Avatar
Hi Paul,
Thanks for this.
I have had to change out the battery on a previous occasion, and bought what was recommended for the bike. And the issue still persisted.
Strange that other bikes, including my previous 955, never exhibited this issue.
I will take on board what you have said about the change of battery recommendation.
Many thanks for the feed back - much appreciated.
GavinD is offline
post #9 of 15 (permalink) Old 04-19-2019, 10:50 AM Thread Starter
GavinD's Avatar
Hi Felony,
Battery on this bile and all my previous, were always plugged in at night to a battery management system.
All previous bikes did not exhibit this.
After a run, the battery levels are always down to just below high. Yet the bike when parked up, after a run, tends to caught once and then not attempt to turn over.
I did ask, and was shown by a mechanic, at idle, there was a good charge hitting the battery....but this was a "look see it is charging".....
I have booked the bike in for a full service and will ask this to be fully investigated.
I have made a note of your suggestion(s) as this is all very good / sound advice for me to learn / apply.
Many thanks for taking time to assist with my bike woes.
Cheers.
GavinD is offline
post #10 of 15 (permalink) Old 04-19-2019, 10:51 AM Thread Starter
GavinD's Avatar
Cloudy,
Many thanks. I had written that I was looking into this at the moment.
However as a Luddite, I do "unsocial media" .. :))
Life choice after many, many years in IT.
However much appreciated.
I will look into an upgraded replacement loom, and see what I can come up with.
Cheers.
Cloudy likes this.
GavinD is offline
Timing marks and Tri Spark Ignition problem tjkoko Classic, Vintage & Veteran 58 11-09-2018 07:12 PM
fuse Bike2b3? Classic, Vintage & Veteran 16 09-28-2018 11:09 AM
2006 Speed4 Ignition and battery intermittent Issues CableGuy Air Cooled Cruisers - America, Speedmaster 1 09-03-2018 09:15 PM
help me wire my 1970 t120 650 cheapstreet Classic, Vintage & Veteran 20 12-09-2017 06:36 AM
Replacement Battery Colt3374 Water Cooled Twins Technical Talk 10 11-15-2017 05:28 PM
