Tiger 1050 starting issue and engine light... - Triumph Forum: Triumph Rat Motorcycle Forums
Tiger 1050 - Mods & Workshop Workshop and technical talk for the 1050 Tiger
LinkBack Thread Tools
Old 09-02-2011, 03:49 PM Thread Starter
Main Motorcycle: Bonneville
Crazy Canadian's Avatar
Other Motorcycle: 2008 Tiger 1050
Extra Motorcycle: 2005 Bonneville T100
This maybe a dumb question but I am in the middle of a move and can't lay my hands on my manual right now... After being out of town for a month I finally got an afternoon free to ride and at first the Tiger wouldn't start. So i charged it and still no luck. Checked fuel and all fuses and started checking all the connections and cleaning anything I found dirty. Still no luck. Finally I tied the clutch open and started to feel around as I pressed the starter to see if I could feel where the click noise was coming from. It was coming from this...
[img width=640 height=477]http://i680.photobucket.com/albums/vv170/4redman/IMG_20110902_133455.jpg[/img]
Pulled it all apart and cleaned it up and finally got the bike started. Now I've noticed that although the bike seems to be running fine the orange check engine light is staying on. As funds are a little tight with moving and all I don't really wanna go to the dealer and am hoping one of you guys knows what's wrong. I checked the oil and all the connections under the seat again but just don't know... And as all my tools and the manual are stuffed in a storage unit I am a stuck with online searching and am not finding much help there...
Crazy Canadian is offline
Old 09-03-2011, 01:51 PM
Main Motorcycle: 2012 Tiger Explorer
tigg-ted's Avatar
Other Motorcycle: Prev.T100,Sprint1050,955i
Sorry but couldn't get your link to work for the photo,
Did you disconnect the battery to charge it?
as this will cause the engine management light to illuminate
but have you tried the three warm-up cycles?
If the fault is fixed the EML will reset!
Run the engine up to full operating temp and allow to cool fully,
then repeat twice more, providing there is no persistant fault all
should return to normal.
Triple Growl makes me Grin!
tigg-ted is offline
Old 09-03-2011, 05:47 PM
This is the pic :
[/IMG]
MiniKissKool is offline
Old 09-03-2011, 07:08 PM
tigg-ted's Avatar
Originally Posted by MiniKissKool View Post
This is the pic :
[/IMG]
starter solenoid and disconnecting it will register as a fault and light the EML
tigg-ted is offline
Old 09-04-2011, 12:26 AM Thread Starter
Thanks for the advice guys! The three warm ups worked and all is okay!
Old 10-20-2014, 02:28 PM
Main Motorcycle: 2001 Tiger
RebRider's Avatar
2001 tiger...havent tried the above and hope that is the issue with mine, got a flat, ran battery down trying to put air in tube, thought was slow leak but wasnt.
RebRider is offline
Old 10-21-2014, 02:41 PM
Supernova
DEcosse's Avatar
Originally Posted by tigg-ted View Post
....Did you disconnect the battery to charge it?
as this will cause the engine management light to illuminate....
That is not correct - makes no difference whether battery is connected or not.
First, there is no possible mechanism for the ECU to even recognize what is going on with the battery unless the key is on as ECU has no constant power connection. But even if the ignition is turned on with a charger connected, it will still not cause an MIL fault.
DEcosse is online now
Tiger 1050 / 07 annoying starting troubles... tiger69 Tiger Workshop (archive) 9 03-24-2011 10:43 PM
Starting Issues Tiger 1050 and others BlindManJack Tiger Chat 2 02-24-2011 11:55 AM
engine warning light: issue? loco Daytona Deliberations 17 07-26-2010 08:42 AM
Engine management light issue. welshrob Daytona675 Forum 1 03-19-2009 09:14 AM
Tiger not starting when engine is hot bykboy Tiger Workshop (archive) 4 10-13-2008 06:55 AM
