'10 Thunderbird, No rear brakes this spring - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
  • 1 Post By danr620
post #1 of 3 (permalink) Old 04-15-2019, 09:17 PM Thread Starter
Newbie
Main Motorcycle: '10 Thunderbird 1600
Other Motorcycle: '15 FZ-07
Extra Motorcycle: '86 YZF 600
Just got the old girl out from under the cover and found there is nothing going on with the rear brake. Fluid was full but a little off-color, so I decided to change it just in case. Cleaned around the reservoir and the bleeder valve, popped the top and cracked the bleeder, and the pedal goes to the running board with no movement in the fluid level. Tightened up the bleeder and tried to get some pressure to build on the pedal, but nothing doing. Am I looking at a master cylinder problem, or have I missed something completely here?
Kutthrowt is offline
post #2 of 3 (permalink) Old 04-16-2019, 02:37 AM
Main Motorcycle: 2014 T-Bird LT
slingshot60's Avatar
Suspect seals in rear master cylinder https://www.bikebandit.com/oem-parts...8757#sch632647 .
If there are no leaks at the caliper piston seals...that would lead me to hose between master and caliper/master itself. On my 2014 LT I use Dealer Tool to bleed brakes, it opens up the solenoid of the ABS component.
slingshot60 is offline
post #3 of 3 (permalink) Old 04-18-2019, 05:19 PM
Main Motorcycle: 2010 Triumph T-Bird
Other Motorcycle: 1998 triumph T-Bird
Extra Motorcycle: 1981 honda xl500
kutthowrt,
Same happened to me a couple of years ago. Had to get the rebuild kit, took a long time to pump all the air out. Like Sling said, need dealer tool to cycle ABS. Think you can do your rebuild and bleed without it, but you will want it to get all the old fluid out.
good luck
Dan
slingshot60 likes this.
danr620 is offline
Thunderbird Storm Rear Brake Pad Replacement TStorm Thunderbird Twin - Technical Talk 13 07-03-2017 06:32 PM
Hagon rear suspension spring rates HinckleyBorn Thunderbird Twin - Technical Talk 3 12-11-2015 04:40 AM
Rear Brakes fail and fade agian Luxlamf Air Cooled Twins Technical Talk 29 11-28-2015 09:08 PM
"Stuck Pig" rear brakes s3g2 Air Cooled Twins Talk 12 06-04-2012 03:50 PM
Racetech spring installation giantkillerrobo Sprint Forum 7 10-01-2007 01:47 PM
