LT MAP Tubes and flat spot issue. - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 12 (permalink) Old 04-17-2019, 08:40 PM Thread Starter
Main Motorcycle: 2014 Thunderbird LT
Scoobersteve's Avatar
Other Motorcycle: 2009 Suzuki Vstrom DL650
There are some good suggestions on here, thanks all. Will get it over to another Dyno dude and try a few things. May even remove the PC5, re-fit the O2 sensors and see how we go. Cheers
Die hard LT owner - you have to be with all the issues mine has had. :-)
Scoobersteve is offline
post #12 of 12 (permalink) Old 04-18-2019, 09:14 AM
Main Motorcycle: 2014 T-Bird LT
slingshot60's Avatar
Keep us posted on your findings. Just to make things right mine will cut out at highway speed between a gearshift change up or down when the idle speed is different.....and is intermittent as previously stated. One bad habit I may have done is max out the fuel tank upon a refill...perhaps causing fuel to go into the overflow tube. Bought my LT second hand with 2500 miles and the 4 screws holding the plate where the oil filter is were stripped. Suffice it to say previous maintenance history is unknown. Pulley bearing had to be replaced at 11k, 2 of the 4 plugs were oil fowled. Working on maintenance overhaul now and replaced plugs again DPR6 EA9 with standard gap. All 4 were nice and tan colored as should be. Replaced fuel filter last year with one from an auto store that was clamp able with seam in middle. Got the correct Mahle fuel filter and replaced it this year making sure I had the rubber intake cover in the right position....and it was. Remainder of maintenance should be completed today....so I can get it out to practice and renew the stale riding skills from winter dormancy.
slingshot60 is offline
MAP sensors on EFI Bonneville- Long post Forchetto Air Cooled Twins Technical Talk 173 06-11-2019 11:33 AM
MAP verses Morgo 750 kit sportsprint Classic, Vintage & Veteran 7 12-05-2015 07:01 PM
FIX–For The Unexpected Shutdown/Stalling Issue (long post) Faster Pastor Thunderbird Twin - Technical Talk 5 11-21-2013 02:51 PM
NEED tubes! & 'Forks by Franks' FattRat Air Cooled Twins Technical Talk 2 07-27-2006 02:21 PM
NEED tubes! & 'Forks by Frank' FattRat Club Cafe' 3 07-27-2006 12:57 PM
