LT Brighter Rear Lamps - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 7 (permalink) Old 08-20-2019, 08:29 PM Thread Starter
Main Motorcycle: Thunderbird LT
I'm a bit paranoid about getting rear ended thanks to a couple of recent incidents.
Has anyone upgraded the rear lamp or added extra lights?
BasilM is offline
post #2 of 7 (permalink) Old 08-21-2019, 06:32 AM
Main Motorcycle: '06 Tiger 955i
VABird's Avatar
Other Motorcycle: '12 T-Bird
Extra Motorcycle: '08 "AmeriMaster"
Although I don't have one, when I see those flashing brake lights they get my attention. probably more than just brighter bulbs. Seen them on eBay as low as $11 and as high as $150.
The ride might be fun, but at the end, it really is the Destination that counts.
John 3:16
VABird is online now
post #3 of 7 (permalink) Old 08-21-2019, 03:26 PM
Main Motorcycle: 17 Triumph Thunderbird LT
I replaced the taillight and license plate light bulbs with LED bulbs. Replacements are pretty easy to find. But the most significant thing I did was install a vizi-tec brake light modulator (http://www.vizi-tec.com/supabrake-3-triumph/). They make a plug and play model for the Thunderbird LT. I am not the most mechanically inclined person, but I was able to do it myself once I found the brake light plug.
Mr. Briggs is offline
post #4 of 7 (permalink) Old 08-22-2019, 06:50 AM Thread Starter
That vizi-tec looks promising.
Do you remember what LEDs you used?
BasilM is offline
post #5 of 7 (permalink) Old 08-23-2019, 07:34 PM
There was an 08-12-16 post by bluheeler on the Thunderbird Twin - Technical Talk page titled LT now has all LEDs. I used the same brake, license plate, and turn signal bulbs he recommended. To save you the time looking for it, I copied and pasted it below. I also replaced the LED headlight bulb I had already installed with a J.W. Speaker 8790 Adaptive 2 LED 7" Headlight, but instead of the auxiliary lights he recommended (I had already found LED H3 bulbs that worked) I installed J.W. Speaker 6045 LED 4.5" Fog Lights. The combination headlight and auxiliary lights provide a lot more illumination both at night and during the day.
Here's the post by bluheeler:
"After having some bulbs burn out in less than two years, I decided to go all LED.
Here's a list of LED bulbs I used to replace stock bulbs.
OPT7 H3 LED bulbs for aux lights.
(You will need to reverse wires in bucket as they are backwards. The white wire is ground and black wire is power. The bulb holder already has a tab to put the white wire terminal on and I spliced a new blade terminal on the black wire to attach to bulb.)
Inertia 12093 RY10w Amber LED bulbs for turn signals.
(These are CANBus friendly. They will hyper flash when the engine is not running, so don't think they are defective if you check them with just the key on like I did.)
Philips 1157 Red LED for brake light.
Philips 194 LED for license plate light.
J.W. Speaker 8790 LED headlight.
(Any 7" LED headlight bulb will work as long as it is less than 4" deep and has H4 connector. The 8790 looks cool.)"
post #6 of 7 (permalink) Old 08-24-2019, 04:23 AM Thread Starter
You're a legend!
BasilM is offline
post #7 of 7 (permalink) Old 08-30-2019, 03:11 PM
Main Motorcycle: '14 Thunderbird LT
bluheeler's Avatar
JW Speaker 6045
Hey BasilM,
Heres an update.
The LED lights for tail and signal lights I installed are all still good and none have failed yet. Brighter than incandescents.
Have the engine running when checking signal lights for proper flash timing. With just key in on position they will hyper flash.
The philips LEDs were available at local pep boys. I got the Inertia 12093 RY10w Amber LEDs online.
bluheeler
06 Bonneville Black
03 V-Star Custom
bluheeler is offline
