Turn Signal Woes - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 18 (permalink) Old 07-26-2019, 11:33 AM Thread Starter
Main Motorcycle: Vulcan 2000LT
Other Motorcycle: Sratoliner
Extra Motorcycle: Thunderbird Storm
Unhappy Turn Signal Woes
Well I finally got my bike together and have been riding it. 2014 Storm.
If I turn my left signal on it works fine. If I turn the right signal on it flashes once and now the left one doesn't work.
If I wait a while the left one works again. So I can't use my right turn signal at all. If it was a flasher I would think that both signals would not work.
There may be a relay involved. Thoughts ?
JJ
Jammin'John is offline
post #2 of 18 (permalink) Old 07-26-2019, 11:44 PM
Main Motorcycle: 2013 Thunderbird 1600 ABS
PapaSmurfMC's Avatar
Other Motorcycle: 2009 Triumph Bonneville
Try swapping bulbs between the left and right signals and see if the problem reverses. There's no flasher relay in TBirds; flashing is controlled directly by circuitry in the instrument cluster.
2013 Blue Marble Haze Thunderbird 1600 ABS
2009 Black Bonneville A1 ("Mag")
Buncha farkles
PapaSmurfMC is online now
post #3 of 18 (permalink) Old 07-27-2019, 10:25 AM Thread Starter
So it's very expensive to just fix the flasher ?
JJ
post #4 of 18 (permalink) Old 07-27-2019, 11:30 PM
I've never heard of anyone having to replace their instrument cluster because of a signal flashing issue. It's a bulb, connector or wiring issue. When the ECU detects what it thinks is the wrong load on a signal line, it does weird things.
Buncha farkles
post #5 of 18 (permalink) Old 07-28-2019, 12:28 PM Thread Starter
The bulb works.
JJ
post #6 of 18 (permalink) Old 07-28-2019, 11:03 PM
The bulb works.
Did you swap left and right signals in the front, checked if the symptoms changed, then swapped the rear and checked again?
Buncha farkles
post #7 of 18 (permalink) Old 07-29-2019, 01:01 PM Thread Starter
Both signals work fine if you don't start the motor. Once you start the motor they don't work right.
JJ
post #8 of 18 (permalink) Old 07-30-2019, 12:10 AM
Are these incandescent bulbs or LEDs with "load equalizers"? Because it sounds like exactly what you'll see with load equalizers on the turn signal lines. The ECU doesn't like them.
Buncha farkles
post #9 of 18 (permalink) Old 07-30-2019, 01:11 PM Thread Starter
Stock incandescent amber bulbs. It's NOT a connection problem since when they light they are bright. I hear no clicking of a flasher when they are blinking.
The bike sat for almost 2 years. Had to replace a fuel injector and now this.
JJ
post #10 of 18 (permalink) Old 07-30-2019, 06:58 PM
The internal flasher is solid state; you won't hear a click. Was the battery disconnected while it was in storage?
Buncha farkles
