Dry Lube for possible belt chirping on a LT? - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
  • 1 Post By TorqueBird
post #1 of 9 (permalink) Old 04-17-2019, 11:07 PM Thread Starter
Main Motorcycle: Thunderbird LT
I asked my mechanic about a slight chirping noise I've been hearing which stops when I disengage the clutch. He suggested it might be the belt which chirps under load but stops when you pull in the clutch and disengage the load. Sounds plausible I guess. He said to spray some dry lube on the pulleys and see what happens.
Presume something like this? https://www.supercheapauto.com.au/p/...d=SCA01080409#
BasilM is offline
post #2 of 9 (permalink) Old 04-17-2019, 11:33 PM
Main Motorcycle: 2013 Thunderbird 1600 ABS
PapaSmurfMC's Avatar
Other Motorcycle: 2009 Triumph Bonneville
Don't spray crap on the pulley. Find a [different] mechanic who knows how to align the belt.
2013 Blue Marble Haze Thunderbird 1600 ABS
2009 Black Bonneville A1 ("Mag")
Buncha farkles
PapaSmurfMC is online now
post #3 of 9 (permalink) Old 04-18-2019, 07:51 PM Thread Starter
I'm sure he does know how. It was more of a troubleshooting exercise. i.e. if the chirping stops we know what is causing it.
But yeah that stuff I linked might not be a good idea as it might be tacky not dry. Anything tacky would attract grit and cause problems.
BasilM is offline
post #4 of 9 (permalink) Old 04-19-2019, 12:12 AM
Putting any kind of treatment on the belt or pulley, not specified by the manufacturer, is a momentary fix at best and possibly damaging or dangerous at worst. With the right tools, aligning the belt is a 15 minute exercise so I'd go there first; if you're mechanically inclined, you can do it yourself. The TBird is [in]famous for the chirping belt, although I've only ever had to realign mine once in the last 6 years between tire changes.
Buncha farkles
post #5 of 9 (permalink) Old 04-19-2019, 01:04 PM
Main Motorcycle: 2012 Thunderbird
Other Motorcycle: n/a
If you’re simply trying to troubleshoot.. you can use a small amount of food grade silicone spray. If the chirping stops.. it’s likely your belt. This is solely for troubleshooting.. and not meant to be a fix. Have your belt adjusted.
joey1970 is offline
post #6 of 9 (permalink) Old 04-21-2019, 12:47 AM Thread Starter
Originally Posted by joey1970 View Post
If youíre simply trying to troubleshoot.. you can use a small amount of food grade silicone spray.
Yep that's the idea. By coincidence I was in the garage and saw a can of silicone spray and the lightbulb in my head flashed. Spray some on my finger and nothing sticks to it so I reckon it's good to try.
BasilM is offline
post #7 of 9 (permalink) Old 04-23-2019, 10:34 PM
Main Motorcycle: '06 Tiger 955i
VABird's Avatar
Other Motorcycle: '12 T-Bird
Extra Motorcycle: '08 "AmeriMaster"
Another temporary troubleshooting technique is rubbing (not your wife's favorite) bar soap on the edge that looks closest to the pulley. Won't last long, but you'll quickly find out that that's where the squeak comes from.
The ride might be fun, but at the end, it really is the Destination that counts.
John 3:16
VABird is online now
post #8 of 9 (permalink) Old 04-24-2019, 02:26 AM
Main Motorcycle: tbird
Silicone lubricant spray has some acetone in it. Don't use that, as in time it may deteriorate the belt ! I tried it till i heard that, then i switched to food grade silicone spray. That is ok on the belt but lasts such a short time it's not worth the effort. The other stuff lasted but i imagine thats because the acetone allowed the silicone to embed into the belt. Not a good thing exceot for noise relief. Try wax, it lasts much longer. There are waxes you can get that are for lubrication purposes which should be good Several people have mentioned using that. I just used candle wax and it lasted a lot longer then silicone and is safe.
DaveM likes this.
TorqueBird is offline
post #9 of 9 (permalink) Old 04-27-2019, 08:38 PM Thread Starter
I'd be worried that wax would get grit stuck to it & degrade the belt. When I get around to it I'll try some silicone spray.
BasilM is offline
Lubing the drive chain - ideas??? jimmy3plugs Hinckley Classic Triples 34 06-08-2013 04:09 PM
Finally got the belt chirp at 2600 miles. Rayzor61 Thunderbird Cruiser Chat 14 04-26-2012 05:18 PM
DuPont Teflon Dry Wax Chain Lube discontinued RICHW Biker Hang-Out 52 03-17-2012 10:08 AM
Chain Dry Lube Spartan Andy Tiger Chat 26 11-06-2011 11:40 PM
Dupont Dry Chain Lube Shakey Street Triple Forum 9 08-31-2008 11:51 AM
