Oil pressure switch - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 14 (permalink) Old 03-13-2019, 01:07 AM Thread Starter
AusTone's Avatar
Oil pressure switch/light
Hi all. I posted this on Chat by mistake:
Bought my 2014 Storm last November with 20000 on the clock. Had the major service done and have only done about 1000 since. The red oil pressure light has started to come on at idle when hot. Oil level good and I've sprayed inside the pressure switch with WD-40 in case there's water in there. It seems intermittent because yesterday it came on after 6kms then went off and stayed off. Thinking of installing an oil pressure gauge, any thoughts?
Cheers, Tony.
AusTone is offline
post #2 of 14 (permalink) Old 03-14-2019, 05:18 AM
Main Motorcycle: Thunderbird LT
Make sure the oil actually is at the correct level. If you read the user guide it will tell you the correct procedure (from memory) idle 5 (or maybe 10??) mins, sit 3 mins, measure with gauge screwed all the way in and the bike straight vertical (not on the side stand). It's a bugger of a job getting the bike vertical when you measure because the slightest tilt makes quite a difference. If anyone else reads this - is there a trick to measuring it by yourself?
BasilM is offline
post #3 of 14 (permalink) Old 03-14-2019, 02:21 PM
Main Motorcycle: 2013 Triumph Thunderbird
Other Motorcycle: previously had HD Deluxe
I tend to put a small concrete block under the bike stand (it took some time to find a block with the right height) and it keeps the motorcycle pretty straight. Since it is still barely tilted toward the stand side, then a slightly lower measurement (between the two marks on the oil stick) is OK.
From previous filling mistakes, it takes about 1/2 liter to raise oil level from the 1st marker to the 2nd marker, so once your oil reaches the 1st marker, you can add just a little more and that's it.
sefri is offline
post #4 of 14 (permalink) Old 03-14-2019, 02:27 PM
Cheers, Tony.
The oil could be heating up if your radiator liquid is low or not circulating correctly. Oil level is not the only issue leading to a red light. Also check if your radiator is not blocked by anything from the front. If the radiator liquid cap -under the fuel tank- was opened and not closed correctly (even if slightly), that leads to overheating as air enters into the radiator system causing the temperature to rise... That is just to mention a few other reasons.
sefri is offline
post #5 of 14 (permalink) Old 03-15-2019, 10:05 AM
This is how I check my oil level. I don't know if temperature of oil matters but I do it while warm.
1. Park the bike on the sidestand.
2. Clean debris from around dipstick.
3. Remove dipstick and wipe off oil.
4. Replace dipstick and screw it in snug but not tight.
5. Get on bike and carefully tilt up to vertical for a few seconds. Then let it back down onto sidestand.
6. Remove dipstick and check level.
I don't use blocks to hold bike vertical while screwing/unscrewing dipstick because end of dipstick is sloshing around in oil and I think that may indicate a false level. I'm old so I need glasses and good light to see new oil on this dipstick. Easy to do by myself and I don't need to take leveling blocks with me when traveling.
jaknife is offline
post #6 of 14 (permalink) Old 03-17-2019, 09:33 PM Thread Starter
AusTone's Avatar
To give an update. I've had the oil pressure switch out and all seems to be good. I'm booked in to the stealers on Thursday for an oil pressure check. Will let you know how it goes.
Cheers Tony
AusTone is offline
post #7 of 14 (permalink) Old 03-21-2019, 07:24 AM
Main Motorcycle: '06 Tiger 955i
VABird's Avatar
Other Motorcycle: '12 T-Bird
Extra Motorcycle: '08 "AmeriMaster"
BTW, installing an oil pressure gauge will only frighten you!
I have one and at idle when warmed up, pressure is alarmingly low! (close to zero)
According to manual, it should be 3-3.6 bar (28-37 PSI) at 3500 RPM.
But if you do install one, it should be pretty simple.
The first pic shows an electric sender (gauge is in the fairing). You could put a mechanical pressure gauge in the same place, but just not be able to see it when riding.
If you do the latter, be sure to get an oil filled gauge or else it'll fluctuate way too much.
The ride might be fun, but at the end, it really is the Destination that counts.
John 3:16
VABird is offline
post #8 of 14 (permalink) Old 03-21-2019, 09:23 PM Thread Starter
AusTone's Avatar
Thanks for that VAbird.
Supercheap have a test kit for $44 so I think I'll get that.
https://www.supercheapauto.com.au/p/...ce/392377.html
Tony
AusTone is offline
post #9 of 14 (permalink) Old 03-27-2019, 01:02 AM Thread Starter
AusTone's Avatar
I've not had the oil pressure checked yet but done the following:
Fresh oil 15-50 semi synthetic. Issue persists.
Replaced oil filter. The light hardly ever comes on now. So the filter was partially blocked after only about 1000 ks. Red light only slightly flickers at idle when engine really hot. TEST while engine hot: while stationary, I reved to 2000 and light goes out and cooling fan comes on, light goes out and stays off while idling. I think I'll order a new oil warning light Switch. I'm thinking that the Internal spring may be clogged making it harder for the oil pressure to push it open.
Cheers Tony
AusTone is offline
post #10 of 14 (permalink) Old 04-05-2019, 01:10 AM Thread Starter
AusTone's Avatar
Well bugger me! I've just replace the oil warning light SWITCH (under the sump) and I have the same issue, ie, the red light flickers when hot. Now I'm a retired electronics technician and I don't know why I didn't do the following test BEFORE I ordered a new Switch, anyway, here's the test:
I disconnected the Black wire from the Switch and the flippin light still flickers, SO, nothing to do with the oil pressure itself but an "earthing" of the wire that goes to the switch, somewhere between the Red LED and the switch connector. I'll investigate further and let you know what I find.
Cheers
Tony
AusTone is offline
Daytona 1200 Oil pressure switch Andrewm7558 Daytona Deliberations 1 09-24-2018 04:15 PM
T140 Oil Pressure Switch AndyT140 Classic, Vintage & Veteran 7 04-23-2018 10:02 AM
Oil pressure gone!!! TThruxton Air Cooled Twins Technical Talk 23 04-02-2014 04:52 PM
HELP!! Throttle cable snapped! hobo Hinckley Classic Triples 22 07-05-2011 10:13 PM
Increasing fuel pressure and WOT power LuckyBonnie Air Cooled Twins Technical Talk 14 06-01-2010 06:45 PM
