Headlight upgrade for the Tbird - Page 6 - Triumph Forum: Triumph Rat Motorcycle Forums
 9Likes
post #51 of 59 (permalink) Old 03-18-2018, 09:57 PM
Newbie
Main Motorcycle: Triumph Thunderbird
I just bought my Thunderbird. It came with a Denali headlight and tonight I took it for my first nighttime ride. I made one adjustment to the light (it was focused about 20 feet in front) and I could only ride with the high beam. I raised it up but am not sure I can get the light output I really want from it. I probably raised it a little too much, so I'm going to drop it a little before I order something new.
Does anyone else have (or had) the Denali light and have any other bulb they can compare it to?
Thanks!
Steve
cruizin54 is offline
post #52 of 59 (permalink) Old 03-19-2018, 08:06 PM
Main Motorcycle: Triumph Thunderbird 1600
TBirdDan's Avatar
Other Motorcycle: 2000 Valkryie Interstate
For those that had to adjust a non-Storm setup, how much did you adjust it and did you use anything to "measure" what you did?
I feel like the light is aimed too low. Guess I could just crank it up a bit at a time and see what works.
Dan.
Ride on my friends....
TBirdDan is offline
post #53 of 59 (permalink) Old 04-15-2018, 03:55 PM
Main Motorcycle: 2012 Triumph Thunderbird
Other Motorcycle: 2015 Honda CBR500r
Extra Motorcycle: 2007 Kawasaki Ninja 250
Hello all. Total Noob here when it comes to wiring. The old headlight has a triple spade connector which plugs right in to my Amazon LED light. What do I do with the two remaining connectors off the old light? Both singles. One is black wire and the other is yellow wire with female spade connectors on both ends. SOS!
Thanks!
Merikanskimoosh is offline
post #54 of 59 (permalink) Old 04-15-2018, 10:56 PM
Main Motorcycle: 2013 Thunderbird 1600 ABS
PapaSmurfMC's Avatar
Other Motorcycle: 2009 Triumph Bonneville
That's for the "position light", that tiny bulb inside the stock headlight that stays on when the ignition key is in the park position. You can tape off or otherwise insulate the two connectors.
2013 Blue Marble Haze Thunderbird 1600 ABS
2009 Black Bonneville A1 ("Mag")
Buncha farkles
PapaSmurfMC is offline
post #55 of 59 (permalink) Old 04-16-2018, 07:29 PM
That was EXACTLY the problem! Thanks.
post #56 of 59 (permalink) Old 04-17-2018, 10:17 PM
Main Motorcycle: 2010 Triumph Thunderbird
Edward Teach's Avatar
Other Motorcycle: '17 Kawasaki Versys X 300
I'd like a Mars light for my T-bird...
All Men under the age of sixty years shall have Bows and Arrows for shooting. Men-Children between seven years and seventeen shall have a bow and 2 shafts. Men about seventeen years of age shall keep a Bow and 4 Arrows - Penalty 6s.8d.
Edward Teach is offline
post #57 of 59 (permalink) Old 04-18-2018, 09:10 AM
Newbie
I had to look up what a Mars light is. Very funny!
post #58 of 59 (permalink) Old 08-02-2019, 01:20 AM
Newbie
Main Motorcycle: 2017 Trophy SE
Other Motorcycle: 2014 Thunderbird
Local shop recommended Cyclops 10.0 H4 LED as replacement for stock bulb in my 2013 Thunderbird. Anyone have experience with the brand, bulb type and installation? Thank you! - Doug
https://www.cyclopsadventuresports.c...ulb_p_192.html
ddeardorf is offline
post #59 of 59 (permalink) Old 08-03-2019, 12:48 PM
Main Motorcycle: '16 Tbird Storm
Other Motorcycle: '07 Speed Triple
Replacement LED bulbs
Hi all, I just bought a '16 TBird Storm and I own a '07 Speed Triple. So I have 4 bulbs to replace. Amazon indicates that these are compatible with my motorcycles. Any opinions or cautions about swapping to these LED bulbs?
https://www.amazon.com/H4-9003-Motor...ype=motorcycle
billips1002 is offline
Is there enough space in the headlight bowl to upgrade to LED? Craig321 Speed Triple Forum 11 03-30-2017 04:31 AM
headlight upgrade advice Joe Goodill Maintenance & Workshop Talk 0 01-08-2017 06:02 AM
What Size is the Headlight on a 2012 Tbird? Snyperx Thunderbird Cruiser Chat 7 07-25-2016 09:48 AM
D600 Headlight Upgrade Mod - Trial andrewed1 Triumph SuperSports 11 01-27-2016 10:48 PM
