Bigger rear tire? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 8 (permalink) Old 12-16-2011, 03:36 PM Thread Starter
Main Motorcycle: '12 TBird
Bigger rear tire?
R.e. the rear tire and fender area:
Can you put a bigger rear tire on to better fill the fender area, so it doesn't look like it's raised quite so high?
I know you can with the Vulcan 900 Custom (which has the same type of high fender profile)...here is its similar stock look:
With the Vulcan, you can take the stock 180 up to a 200 to better fill that rear area, and without any modification. Some even take it up to 230, though that does require some modification(s). Same aesthetic option w/ the TBird? Or does the bike's build and wheel well spacing require you to keep the stock size?
RC65 is offline
post #2 of 8 (permalink) Old 12-16-2011, 09:28 PM
Main Motorcycle: Triumph Thunderbird
Other Motorcycle: 91 FXLRC
Extra Motorcycle: 90 HD Sportster 1200
Greetings,
I've inquired about the same at my dealer... and what we have found is that there are few tires out there to fit the Tbird... Even finding the same brand front & rear is limited.
hagatha
hagatha is offline
post #3 of 8 (permalink) Old 12-16-2011, 10:38 PM
Main Motorcycle: 2010 Triumph Thunderbird
Another option you could look into is a custom rear fender that sits lower on the sides. Putting a taller tire on will shorten the distance the suspension can travel, so you'd be sacrificing performance for looks. Bringing the fender down on the sides a couple of inches will change the look, but keep the travel.
Lantesh is offline
post #4 of 8 (permalink) Old 12-17-2011, 02:23 AM Thread Starter
Originally Posted by hagatha View Post
Greetings,
hagatha
Thanks, that's what I was afraid of. Oh well, it wasn't a necessary change, just would've been nice. TBird's a great-looking bike either way.
RC65 is offline
post #5 of 8 (permalink) Old 12-19-2011, 07:22 PM
Main Motorcycle: Trophy SE
Other Motorcycle: Honda CB900F 919
Extra Motorcycle: Honda CB750A Hondamatic
The standard tire on the back is a 200/50R17... I am currently using a 200/55R17, and it fits fine. The tire is about 2cm taller in diameter, and that doesn't cause any problems at all for height issues. It does throw the calibration of the speedometer off, however, and I am now showing 2-3% less than actual, rather than 2-3% more than actual.
Past Bikes:
2006 Suzuki Boulevard S50
Wells is offline
post #6 of 8 (permalink) Old 12-20-2011, 11:08 PM
What brand is the tire?
hagatha
hagatha is offline
post #7 of 8 (permalink) Old 12-21-2011, 11:51 AM
hagatha
Avon Cobra 200/55R17
Past Bikes:
Wells is offline
post #8 of 8 (permalink) Old 12-21-2011, 05:53 PM Thread Starter
Can you post a picture of your bike from the side so we can see the visual difference (if any)?
RC65 is offline
Stock tire sizes or go bigger on the rear? mikester2008 Air Cooled Twins Technical Talk 13 12-08-2010 10:55 AM
Bigger Rear Tire luigi Speed Triple Forum 12 01-28-2010 08:42 PM
Bigger rear tire??? x-tended swingarm?? Speedquest Speed Triple Forum 1 10-05-2006 10:56 PM
Bigger rear tire Limey Speed Triple Forum 10 05-20-2006 01:55 AM
Bigger rear tire? Hinckley Classic Triples 7 05-29-2004 01:43 PM
