Spark Plug Removal - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 13 (permalink) Old 11-29-2011, 11:23 AM
Main Motorcycle: 2011 Tbird
BMK9251's Avatar
Other Motorcycle: 2011 Tbird
Extra Motorcycle: 2011 Tbird
Originally Posted by dazco View Post
I don't store it, but i often don't ride for as much as a month. Occasionally even more. I don't ride in wet under any circumstances, and in cold i seldom do either. And with all i've read about ethanol i feel even more obligated to my bike to insure it's good for a long sit.
It gets cold there?
BMK9251 is offline
post #12 of 13 (permalink) Old 12-05-2011, 11:00 AM
Main Motorcycle: Trophy SE
Other Motorcycle: Honda CB900F 919
Extra Motorcycle: Honda CB750A Hondamatic
As noted, you do not have to remove the tank to get to the spark plugs... but let me tell you, it makes getting to them a heck of a lot easier!
That being said, if you are going to fire it up once or twice a month, then I say don't bother. If you are worried about the cold start bit, hook up an electric heater to blow on the engine for an hour before you fire it up to warm up that oil a bit first.
Past Bikes:
2010 Triumph Thunderbird
2006 Suzuki Boulevard S50
Wells is offline
post #13 of 13 (permalink) Old 12-05-2011, 04:39 PM
First rule of thumb in this business:Never make anymore work for yourself than ya have to.
The trick to doing this job after the tank is raised is to unplug and lift the coils off,then R+R the plugs.And ya do em one at a time.The two outer plugs are easy to get at and done from each the side of the machine.However,I find that performing the task of accessing the two inner plugs is best done from the front of the machine,while straggling the front wheel.When goin after the inside right plug,which is the hardest one to get at,you'll have to remove one or two small screws that hold a plastic cover in place on top of that plug/coil.After the screw[s] are out,just move that cover a tad in either direction just enough to access the coil and then the plug.Then just move it back into place and install the screw[s].
And don't forget to put never seize on the threards of the plugs and to apply die electric grease on the coils where they push down onto the plugs,and around the outer edges of the coils where they push down into the cyliner head.The next time ya service em, you'll be glad ya did that.You'll see what I'm talkin about when ya get into the job.I think the whole job,start to finish,took me alittle over an hour.Needless to say,the next time ya do it,it will be easier and quicker.Like anything else,the first time is ALWAYS the hardest. Dave!!!
davetac1 is offline
Spark plug removal Steiny Speed Triple Forum 7 06-18-2011 03:16 AM
spark plug removal eatdrinkadam Air Cooled Twins Technical Talk 16 04-16-2008 12:12 PM
Spark plug removal aussie Hinckley Classic Triples 14 08-28-2007 12:59 PM
Spark Plug Removal wenzel850 Air Cooled Twins Talk 7 01-04-2006 09:15 PM
spark plug removal cameracsc Air Cooled Twins Talk 7 08-02-2005 09:31 PM
