erratic idle1700 storm - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 5 (permalink) Old 11-15-2011, 06:48 PM Thread Starter
Main Motorcycle: Thruxton
anyone else have an idling problem with their Thunderbird storm. bike seems to idled between 900 and 1500 RPM. When shifting and between gears bike almost seems to be on cruise control very slow to return to idle
FLJay is offline
post #2 of 5 (permalink) Old 11-16-2011, 12:14 PM
Main Motorcycle: 1971 T100C
Other Motorcycle: 2011 Triumph 1700 Storm
Something is not right. Mine is 900rpm at idle. Probably a sensor. Take it to the dealer.
I had an air pressure sensor go bad that caused similar behavior.
toxic is offline
post #3 of 5 (permalink) Old 11-16-2011, 02:37 PM
Main Motorcycle: T-Bird
Did you do the 12 minute tune?
TBRider is offline
post #4 of 5 (permalink) Old 04-07-2012, 05:27 AM
Main Motorcycle: speed master Tbird storm
Other Motorcycle: RGV 250 KTM superduke
Extra Motorcycle: thunderbird storm
what is the 12minute tune?
joeboy is offline
post #5 of 5 (permalink) Old 04-07-2012, 06:21 AM
Main Motorcycle: Thunderbird 1600
Disco Steve's Avatar
Other Motorcycle: Kawasaki z650 chop
Start the bike without touching the throttle. Leave it running until the fan kicks in, then start timing. Once it has run for 12 minutes, I usually give mine a minute or so over to be sure, turn it off.
Start as normal and the bike should have self adjusted. This will get rid of a lot of problems like yours. Not all of them but it's cheap and easy to do.
Cleared up a couple of minor tuning problems in the past, and is probably a good first step if you are having problems.
Disco Steve is offline
Erratic idle jimmy bush Classic, Vintage & Veteran 21 10-12-2011 06:49 PM
Erratic Speedometer blackspring Air Cooled Twins Technical Talk 2 10-09-2011 02:26 AM
Erratic Idle gt1jimi T3 Sport / Touring Forum 2 05-19-2007 05:31 AM
Erratic Tachometer BigAl8295 Hinckley Classic Triples 5 04-29-2007 01:03 PM
Erratic tachometer tipere RAT - Canada 3 05-27-2005 06:14 PM
