Right side oil leak... failed warantee plan... - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 12 (permalink) Old 11-10-2011, 01:46 AM
Main Motorcycle: 2014 Scram "The Crow"
Draeger's Avatar
Other Motorcycle: 98 Honda Valkyrie
I had the same thing.
Fix: Cold bike, unscrew the bolt, replace the crush washer, (I think it torques back to 50nm but check to be sure) and you're good. You'll lose a bit of oil, so don't forget to top up.
Mine was done under warranty and I watched them fix it in all of 5 minutes. Hasn't leaked since. Frustrating that it happened though...
What if there were no hypothetical questions?
Draeger is offline
post #12 of 12 (permalink) Old 11-10-2011, 05:42 PM
Main Motorcycle: vincent black shadow
tadpoll's Avatar
Hi Michael. The problem you have is the copper washer has fine machine markings which allow leakage, torque is not critical. its only a plug really, similar to a sump plug, take it off and dress the washer on some fine emery paper until its nice and smooth , u can use a smear of silastic to be sure it seals if you wish (i didnt) and refit, just tighten it up snug..its a commom fault, cheers, Tadpole
tadpoll is offline
Oil leak from primary side 71/72 trayden Classic, Vintage & Veteran 15 06-21-2010 02:18 PM
Right Side Engine Oil Leak Berman95 Sprint Forum 13 01-23-2010 10:42 AM
Primary side leak... Big 4's 64 Thunderbird Cruiser Chat 1 07-24-2009 05:40 PM
left side oil leak jester955I Sprint Forum 9 09-26-2008 08:57 PM
Oil leak, right-side oil cover Rincewind Tiger Workshop (archive) 2 05-30-2007 11:36 PM
