How to remove baked plastic off of pipes - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 7 (permalink) Old 09-24-2011, 06:06 PM Thread Starter
Main Motorcycle: 2010 Triumph Thunderbird
Other Motorcycle: Norton Commando
Had some trash bags blowing around the road and couldn't avoid them....they subsequently melted and became almost petrified onto the pipes. Tried adhesive remover but no luck. Any help is appreciated...don't wanna ruin my British Customs
madpaddy1 is offline
post #2 of 7 (permalink) Old 09-24-2011, 06:40 PM
Main Motorcycle: Triumph T120 Cinder Red
When your pipes are hot remove as much as you can by just peeling it off. Next I gambled with a blade and lightly scraped as much as I could, it paid off no scratches to the pipes at all. Time took care of the rest, I paid special attention to the area at every wash it is all gone now. You can also try goo gone and a dish scrubber, but you have to be careful not to over do it as you can damage the chrome by the heavy scrubbing. But then again I have a lot of patience and figured I can wear that as proof of my riding the crap out of my bird. there is nothing that time can't fix
roguebird is offline
post #3 of 7 (permalink) Old 09-24-2011, 10:32 PM
Main Motorcycle: 2014 Scram "The Crow"
Draeger's Avatar
Other Motorcycle: 98 Honda Valkyrie
I've had something similar happen... used tons of chrome polish and a razor blade held very flat to the pipes to shave off the goop. Worked out well.
What if there were no hypothetical questions?
Draeger is offline
post #4 of 7 (permalink) Old 09-25-2011, 12:42 AM
Main Motorcycle: 2011 Tbird
BMK9251's Avatar
Other Motorcycle: 2011 Tbird
Extra Motorcycle: 2011 Tbird
Heat up the pipes and wipe with a rag wet with WD40, Easy OFF oven cleaner on hot pipes works as well but be sure to SPRAY THE RAG...NOT THE BIKE as the over spray eats paint.
BMK9251 is offline
post #5 of 7 (permalink) Old 09-25-2011, 02:42 AM
Main Motorcycle: 2010 Bonneville T100
Other Motorcycle: 2013 TW200
Extra Motorcycle: 2014 V-Star 950
I had the same thing happen and I used a wet microfiber cloth on the hot pipes to get the bulk of it off then I used fingernail polish remover to melt the plastic away once it was hardened.
Dette is offline
post #6 of 7 (permalink) Old 09-25-2011, 10:22 PM
Main Motorcycle: 2007 Thrux & 2010 TBird
mvagusta's Avatar
Easy Off oven cleaner. Just follow the instructions (although ignore the part about heating up the oven, the pipes will get too hot, too quick). I tried "warm", but then let the bike cool first...it may take a few applications but will take everything off with no scratching, no blades, and no risk of damaging your shiny down pipes.
mvagusta is offline
post #7 of 7 (permalink) Old 10-14-2011, 12:47 AM
Main Motorcycle: 2011 Triumph Thunderbird
Extra Motorcycle: 1979 Bonneville project
Col. Brassy. Probably mis-spelled. Same thing happened to my Roadstar. Let the pipes cool, picked at it a while then got the bottle of Col. Brassy. Squirted a liberal amount on a micro cloth and started rubbing. No plastic and the shiniest that chrome had been since I bought it.
sleepyjohn is offline
Remove melted plastic from exhaust Shadowsmurf Air Cooled Twins Talk 20 05-24-2012 12:32 PM
How to remove what is left of plastic fuel connector? Razzoo Sprint Forum 7 08-05-2010 04:55 PM
removing baked on bugs etc from header pipes? dazco Maintenance & Workshop Talk 5 08-16-2009 03:37 PM
Melted Plastic on Pipes tpshotta Maintenance & Workshop Talk 7 05-06-2009 11:04 AM
How do you remove the plastic fork slide protectors? 2112 Air Cooled Twins Technical Talk 7 07-11-2007 08:07 AM
