EBC brake pads - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 5 (permalink) Old 09-18-2011, 03:55 PM Thread Starter
Main Motorcycle: 2010 Triumph Thunderbird
robertrichhart's Avatar
Other Motorcycle: 2012 Kawasaki Ninja
Thumbs up EBC brake pads
Just replaced the OEM brake pads with EBC HH sintered pads, and what a difference, much improved braking power, no chattering, and no hint of fade... And I'm still working on breaking them in, so far so good!
robertrichhart is offline
post #2 of 5 (permalink) Old 10-19-2011, 12:24 PM
Main Motorcycle: 2012 Red/Blk Thunderbird
Other Motorcycle: Always looking for one
Smile
Just replaced the rear pads with EBC HH also and the difference is immediately felt. Only got 7000 miles from the stock pads. Can't wait for the front to wear down so they can receive the same EBC HH pads.
BullClark is offline
post #3 of 5 (permalink) Old 10-19-2011, 02:30 PM
Main Motorcycle: Trophy SE
Other Motorcycle: Honda CB900F 919
Extra Motorcycle: Honda CB750A Hondamatic
7k miles on the rears pads seems to be about par for the course. I have now standardized on replacing the rear pads when I replace the rear tire, since they both seem to have about the same life-span. The pads last a little longer, but getting them off is such a pain in the butt that you may as well do both at the same time, since the wheel is already off.
Past Bikes:
2006 Suzuki Boulevard S50
Wells is offline
post #4 of 5 (permalink) Old 10-20-2011, 12:15 AM
Main Motorcycle: THUNDERBIRD
Other Motorcycle: HONDA VT750DC
You can replace the rear pads without removing the rear tire.
linkdog is online now
post #5 of 5 (permalink) Old 10-20-2011, 01:24 AM
Yes, and tho it appears to be a major pain it's much simpler than it seems. Still a bit of a pain, but it only takes about 20 minutes. Probably less after a few times but i only did it once. Fronts are stupid easy. Just installed my 3rd set a couple days ago. But as Dave always screams about () you should clean the pistons up so when they are pushed back in they don't take a bunch of dirt with them to ruin the seals. Thats the one thing i haven't done on the rear, but i do blow it out well with air. Should probably squirt some cleaner in there and then hose it out. The fronts i clean real good before pushing them back in since they're so easy to get to.
dazco is offline
Brake pads English_Spanner Air Cooled Twins Technical Talk 10 08-23-2008 06:23 PM
Brake pads Pokeyjoe Air Cooled Twins Technical Talk 4 04-28-2008 07:18 PM
Brake Pads Mantooth04 Club Cafe' 6 06-07-2007 07:46 PM
Brake Pads Jeff02 Air Cooled Twins Technical Talk 16 06-29-2006 12:11 PM
