Thunderbird storm problems - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
post #21 of 65 (permalink) Old 09-18-2011, 07:08 AM Thread Starter
Main Motorcycle: HD ROADKING
Graeme12's Avatar
More Problems
Picked the Bike the other day only rode it for a short time and all seemed well as I mentioned in previous post.
Yesterday went on a longer ride and found when I was shifting down to 3rd 2nd and 1st gear they would not engage even when I was stationary I had to keep banging on the gear selector.
Took it out today and had the same issues its either a Monday Bike or a Friday bike I am sure of that.
So tomorrow its back to the dealer and I will be contacting Triumph directly then I am getting rid of this thing, 3 months old and very disappointed.
No triumphs for me ever again.
Regards
Graeme
Graeme12 is offline
post #22 of 65 (permalink) Old 09-18-2011, 08:59 AM
Main Motorcycle: 1971 T100C
Other Motorcycle: 2011 Triumph 1700 Storm
Mine does the same thing. It doesn't like to drop down multiple gears with the clutch in. I've had other bikes that have done this so I didn't give it much thought.
If you drop down one gear at a time mine is fine. It's only with clutch in I have problems.
I would be interested in what others have experienced.
toxic is offline
post #23 of 65 (permalink) Old 09-18-2011, 10:58 AM
Main Motorcycle: Thunderbird 1600
Graeme,
I don't think this is a triumph issue. My last bike, Kawa Vulcan, did the same thing. It is an issue with how motorcycle clutches are designed. They don't do very well at shifting when stationary. If you downshift while rolling to a stop, you shouldn't have that issue.
If you have to shift at a stop, release the clutch just to the beginning of the friction zone as you down shift each gear, and it should shift just fine. Obviously, cover your brake, just in case you let the clutch go too far.
Randomo is offline
post #24 of 65 (permalink) Old 09-18-2011, 11:30 AM
Main Motorcycle: 2010 Thunderbird 1600
oldgreybull's Avatar
Other Motorcycle: 2002 Suzuki Volusia
I'm not sure exactly how you're shifting down, or if you're trying to go past several gears at one time. I can do what I think you're describing on my Volutia.
However, regarding the Thunderbird, page 44 of my owner's handbook, 2nd column, top, in bold print, says:
"The gear shift mechanism is the 'positive stop' type. This means that, for each movement of the gear shift pedal/lever, you can only select each gear, one after the other, in ascending or decending order."
Perhaps you're talking about something completely different, but thought I'd mention it just in case.
"Do what you can, with what you have, where you are." - Franklin Delano Roosevelt
oldgreybull is offline
post #25 of 65 (permalink) Old 09-18-2011, 12:37 PM
Originally Posted by Randomo View Post
Graeme,
Agreed. If he's saying it does this while moving tho, then it IS a problem. Seems he is, tho the way it's worded is a bit confusing.
Thats sounds as if to say that when stationary it should be easier. But stationary is where no bike will do that well w/o having to keep banging on it. If it's doung it while moving tho theres a definate problem obviously.
dazco is offline
post #26 of 65 (permalink) Old 09-18-2011, 05:12 PM Thread Starter
Graeme12's Avatar
Further explanation
Hi all,
Sorry if I have not been clear, the issue is gearing down whilst moving. I have done well over 250000 km's on my various bikes. I have experinced gear selection issues when stationary on my other bikes as well usually through lazy gear selection.
This is has been happening when I have been cruising in 5th and 6th gear for a while.
When I start to come down through the gears, always one at a time. I get 3rd, 2nd and 1st gear, it won't go into gear and feels like it's in neutral. When you do eventually stop it still won't find it. There has been a number of times when I have been shifting down to go around a cnr thinking I am in second only to find it's still in 4th gear causing the motor to labour and chug. This is not a good place to be.
This has only been happening since I got the bike back after a switch that controls the ecu was replaced.
Hopefully this explains my issue slightly better.
Regards
Graeme
Graeme12 is offline
post #27 of 65 (permalink) Old 09-19-2011, 04:25 AM Thread Starter
Graeme12's Avatar
Here's hoping
I contacted Triumph Australia today and spoke with the head service tech. He was very helpful as I described all my issues with this bike.
The fork legs and exhaust are all cosmetic and have been rectified under warranty.
The engine management system is fixed. So far so good.
As for my shifting issues as soon as I told him what the issue was he immediately said he new what the problem was and I was to take it down to my Triumph dealer right away.
I took it down to them, it appears there is some shim in between the gear lever and shifter linkage, they sometimes dry out and dont allow the pedal to reset itself or something like that.
Anyway they pulled it apart and greased the splines and this shim that looks like a flat 3/4 washer.
I took it for a ride and it appeared to work itself out. It now appears to be working.
So here's hoping its ok now.
Regards
Graeme
Graeme12 is offline
post #28 of 65 (permalink) Old 09-19-2011, 11:37 AM
Sounds like you've got it sorted out - "all's well that ends well". Now go ride and enjoy!
post #29 of 65 (permalink) Old 09-19-2011, 11:53 AM
Great, glad they got it done. Always a worry because....well you know how i feel about dealers. Maybe you got a good one. anyways, good on ya.
dazco is offline
post #30 of 65 (permalink) Old 09-19-2011, 08:09 PM
If the clutch isn't adjusted correctly,you will have problems shifting both up and down.The free play at the lever should be 1/4 inch.Is IT??? Dave!!!
davetac1 is offline
Thunderbird Vs Storm FireyPete Thunderbird Cruiser Chat 16 07-15-2012 02:25 PM
Thunderbird Storm... BATMAN Thunderbird Cruiser Chat 31 02-18-2011 09:45 PM
Thunderbird Storm versus? Rats4Ryan Thunderbird Cruiser Chat 4 01-19-2011 12:24 PM
