1/2 inch lower rear schoks, 200/55/17 rear tire - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 1 (permalink) Old 09-09-2011, 06:00 PM Thread Starter
Main Motorcycle: 2012 HD CVO Convertible
Question 1/2 inch lower rear schoks, 200/55/17 rear tire
I need some feedback from the veterans of this forum, here is how it goes I am planning to improve my rear suspension by installing 1/2 lower pair of Hagon Nitro shocks customized with 23Kg springs, I already tested them with 26Kg springs and they were too stiff for my taste so I send them back to Hagon to be switch with the 23Kg that I bet will solve the stiffness problem, well I am also planning to install a 200/55/17 rear tire at the same time so the 1/2 inch am losing on the shocks is brought back on the tire 10mm taller profile with the advantage of more rubber which translates on a more cushion on bumps and holes + better handling in curbs while keeping same geometry of the bike, the only problem I see here and that’s were I need the feedback is that the under side of the rear fender will be about an inch closer to the tire which I think will not be a problem as a solo rider that I do 90% of the time but how will it be if I have a passenger on the rear?
Charles Lamb is offline
Hagon rear shocks/150 rear tire ROBD Air Cooled Twins Technical Talk 13 03-29-2013 06:43 PM
17 inch rear wheel conversion cam7777 T3 Sport / Touring Forum 5 06-19-2010 03:21 AM
Rear Suspension and Rear Tire Relationship Apex Twin Club Cafe' 8 05-26-2010 08:15 AM
Cannot find a 5.5 inch morad rear rim. bueller Hinckley Classic Triples 3 02-27-2009 08:48 PM
16 to 17 inch rear wheel b2brand Hinckley Classic Triples 8 03-25-2007 05:51 PM
