Fuel Gauge vs low fuel light - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 2 (permalink) Old 09-09-2011, 01:01 PM Thread Starter
Newbie
my 2010 tbird fuel gauge is acting up (shows 3/4 full when really low on gas). quick question to someone with a shop manual: is the low fuel light sensor independent of the fuel gauge sensor? if it is, then I won't worry about it. if they use the same sensor, I might have to take it to the shop.
p.s. I had the sticky speedo problem early on and my dealer replaced it with no questions.
dmh2000 is offline
post #2 of 2 (permalink) Old 09-09-2011, 01:28 PM
Might be a ECU issue. You might try disconnecting the battery and leave it off for a minute, then replace it. that will erase the adaption i believe a reset certain things like the fuel gauge. It may show no fuel after you do that but will gradually come back. Go fill up and after a few miles it should show correctly and hopefully will be correct. if not you can try reloading the tune if you have tuneecu. But if it is a ecu issue i bet the battery disconnect will fix it. I've had similar issues that straightened themselves out when you give the ECU a slap in the face one of several ways.
dazco is offline
low fuel light/fuel gauge malfunction keystiger Tiger Workshop (archive) 16 05-19-2010 01:05 PM
Fuel Gauge & Light Troubles CMB Sprint Forum 4 06-30-2007 08:31 AM
Fuel Gauge Low Fuel Light problem any ideas ? CYNCRZR Sprint Forum 4 06-10-2007 12:36 AM
Fuel Gauge OK, Low-Fuel light intermittent andy-D Tiger Chat 3 11-16-2006 05:46 PM
Rocket fuel gauge and light BC-Rocket The Rocket Science Forum 1 11-02-2006 11:16 PM
