07/09 build vs. 12/09 build... - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 6 (permalink) Old 09-06-2011, 02:29 PM Thread Starter
Main Motorcycle: Thunderbird
I'm looking at two Tbirds, identical except for color. I can get a better deal on the July build than the December build. Is it worth having one over the other? Looks like the December build will cost me $500-$1000more.
Tallboy67 is offline
post #2 of 6 (permalink) Old 09-06-2011, 03:48 PM
Main Motorcycle: 2010 Triumph Thunderbird
Well from what I've read here and at "the other place" the earlier bikes had the cams that are susceptible to the compression release mechanism breaking. It is however unclear for how long those cams were used, so a 12/09 bike might still have those same cams anyway. My bike was built in 12/09, and the seat bracket recall did not apply to my bike, but it would for the 7/09 bike. I did have to have the fender bolt recall done, and the ABS bolt recall.
Lantesh is offline
post #3 of 6 (permalink) Old 09-06-2011, 07:23 PM
Main Motorcycle: 2010 Thunderbird 1600
oldgreybull's Avatar
Other Motorcycle: 2002 Suzuki Volusia
I'll defer to Dazco who will surely weigh in, but the compression release issue doesn't seem to have caused any issues and the recalls are all covered anyway. If you go with the earlier build just make sure that they will comply with all recall notices prior to delivery; once that is done it's a mute point anyway.
"Do what you can, with what you have, where you are." - Franklin Delano Roosevelt
oldgreybull is offline
post #4 of 6 (permalink) Old 09-07-2011, 01:41 AM
Other Motorcycle: 2009 Kawasaki Concours 14
Mine is a 2/10 and I had a broken decompressor; it was just spinning free on the end of the camshaft causing sort of a sputtering loss of power effect. I'd had the bike less than a month when it happened. Not sure when that issue was fixed and not saying it would happen to you, but it is note worthy. It took over a month (almost 6 weeks) to get replacement parts. It was frustrating because it could be so intermittent and took a couple different times in the shop for them to figure out what it was.
Better living through chemistry.
SimonSaysDie is offline
post #5 of 6 (permalink) Old 09-08-2011, 01:20 AM
Thanks for the heads up; I'll keep listening. Waiting for parts is always the real bummer. Waiting for accessoris is annoying but at least the bike is still operable.
I gather from your post that if it breaks I'll know it?
post #6 of 6 (permalink) Old 09-08-2011, 11:46 AM
Yeah, it'll still run and the symptoms may go from being very intermittent to being very constant, but either way it's obvious it isn't right.
the build is on!!!!!!!!!!! tims007 Sprint Forum 9 10-05-2010 05:22 PM
What would you build? kurt_3_0_1 Air Cooled Twins Technical Talk 3 11-04-2009 12:43 AM
My First Build marko7717 Member's Restoration & Rebuild Projects 2 09-03-2009 06:21 PM
Build it myself or job it out? looseparts Classic, Vintage & Veteran 22 05-30-2009 02:01 PM
CVK re-build kit Redrider736 Club Cafe' 6 12-04-2008 10:42 PM
