Brake pads? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 11 (permalink) Old 08-01-2011, 11:38 PM Thread Starter
Main Motorcycle: Triumph Thunderbird
Other Motorcycle: 91 FXLRC
Extra Motorcycle: 90 HD Sportster 1200
Brake pads?
Greetings,
I just took my Tbird in for the 1 yr service... I was told that I only had 20% of my rear pads left and 80% on the front...
I know it depends a lot on how you drive, but what kind of mileage can you expect out of a set of pads?
Now, after I got my bike home from the service... it was making a lot of noise... I thought it was the belt so I took it back... they checked it out (good) and found that my rear disc is 20,000 out of line... they say that is what caused the pad to wear out so quickly...
Whats your opinion?
hagatha
hagatha is offline
post #2 of 11 (permalink) Old 08-02-2011, 12:07 AM
Some get as little as 6000 on the rears. I'd say i'm getting about 8k and 12k rear and front respectively. Front go further since there are 2 calipers sharing the duty. I put EBC sintered pads in last time and they went about the same as the stock pads which is amazing considering the stock pads on my speedmaster lasted about 1/3 as long as the EBC's.
dazco is offline
post #3 of 11 (permalink) Old 08-02-2011, 01:51 PM
Main Motorcycle: Trophy SE
Other Motorcycle: Honda CB900F 919
Extra Motorcycle: Honda CB750A Hondamatic
My first set of rear pads lasted only 6k. My second set are currently at 15k, but are pretty much gone... The fronts have yet to be replaced after 21k. I have replacement pads waiting for both front and rear, but have yet to actually do it.
Past Bikes:
2010 Triumph Thunderbird
2006 Suzuki Boulevard S50
Wells is offline
post #4 of 11 (permalink) Old 08-02-2011, 07:23 PM Thread Starter
I'd suggest to both of you to have the dealer put the dial on your rear disc... 20 thousandth's doesn't sound like much but it could cause pads to wear faster and even cause bluing if it is out of line...
hagatha
hagatha is offline
post #5 of 11 (permalink) Old 08-03-2011, 11:56 PM
Main Motorcycle: Triumph Thunderbird 1600
Baltothunder's Avatar
Other Motorcycle: '83 Honda Magna VF750C
BTW, it's .020"....
That should be a warranty replacement I would think....
2nd Officer Harbor Chapter #215 Southern Cruisers Riding Club
Never take for granted what you have been given, and what you have earned....
Baltothunder is offline
post #6 of 11 (permalink) Old 08-16-2011, 04:07 PM
Main Motorcycle: 2016 Thruxton
andrew65's Avatar
Other Motorcycle: 2012 Street Triple R
I change out the rear pads with every rear tire, usually about every 8-10k miles and they are usually just about gone by that time, I have almost 29k miles on the bike now and still haven't done the fronts, maybe at 30k interval it may be time to change those, we'll see.
andrew65 is offline
post #7 of 11 (permalink) Old 08-17-2011, 02:29 PM
Just brought the bike into the shop for another set of rear brake pads. The only thing that bothers me about changing these pads is not the pads, but the physical replacement of them. It seems a bit silly that you need to remove the rear wheel in order to get at them!
Past Bikes:
Wells is offline
post #8 of 11 (permalink) Old 08-17-2011, 02:38 PM
you don't have to ! the last set i put in i didn't remove the wheel. You need to remove the muffler on the left tho to get to it. It's a bit of a pain, but i was surprised i actually completed it within about 15 minutes. The part that seemed like it would be impossible was pushing the pistons in and then getting the pads in right. But that all happened pretty easily even tho you;'re sorta flying blind since it's hard to see what you're doing. Overall it was much easier than i thought it would be, which is the opposite of most other experiences i have working on this monstrosity.
dazco is offline
post #9 of 11 (permalink) Old 08-29-2011, 12:32 AM
Main Motorcycle: Rocket 3 Touring 2014
Other Motorcycle: Speedmaster 2004
Wink The rear brake pads
You dont even have to remove the muffler, took us Gary and me 15 min to do the
rear brake pads. Just lift the bike up to a suitable hight, jack the rear end take a chair under
your butt and start with the procedure above. Its easy when you sit under the bike.
Speedmaster 2004 in Espoo, Finland (summer)
Thunderbird 2010 in Oceanside, San Diego County, Ca. gone
IBA Finland SS1000
PappasGarage is offline
post #10 of 11 (permalink) Old 09-01-2011, 02:10 PM
Sub
Sub's Avatar
Send a message via AIM to Sub
Has anyone changed to grippier pads? I think the front takes a bit more pressure than necessary.. I can do two finger pulls on my other bikes, but this guy requires 3-4!
Sub is offline
brake pads rnexussix Speed Triple Forum 2 11-26-2009 06:09 AM
Brake pads for SM rockDAWG Air Cooled Cruisers - America, Speedmaster 5 08-18-2009 02:04 PM
Brake Pads pabonne Air Cooled Twins Technical Talk 11 09-22-2007 07:28 PM
Brake pads kevoz Tiger Workshop (archive) 8 11-11-2006 07:05 AM
