Thunderbird dual headlights - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 6 (permalink) Old 06-29-2011, 09:25 PM Thread Starter
Main Motorcycle: 2010 Thunderbird 1700
bondage007's Avatar
Does anyone know how or has changed this single headlight to a double as on Storm? I don't like the look of auxillary light bar and think a single light in my area would be enough.
Could it be as easy as buying dual lights and replace without cutting wires?
Thanks
John
bondage007 is offline
post #2 of 6 (permalink) Old 07-01-2011, 06:08 PM
Main Motorcycle: 05 speedmaster - black
Other Motorcycle: 2010 Thunderbird - silver
Extra Motorcycle: 2014 thruxton - black
I have HD fat bob dual headlights on my t-bird. easy install, looks great.
search this forum and the other t-bird forum lots of dual headlight conversions. So many did change the headlight that Triumph copied the dual idea for the storm.
see my wicked black speedmaster
904cc, 12:1 JE racing pistons, thunderbike cams, ported and polished head, scepter pipes, 39mm FCRs.
mag10 is offline
post #3 of 6 (permalink) Old 07-05-2011, 02:58 PM
Main Motorcycle: '10 Thunderbird, '12 RIII
Other Motorcycle: '05 Speedmaster
I tried searching this site...I'm sure I'm doing something incorrectly...but I can't seem to find any great details on the dual light conversion. Does anyone have a link showing what dual lights are used, and do we need cable extensions, etc...
Thanks!
DocT is offline
post #4 of 6 (permalink) Old 07-05-2011, 06:10 PM
try this http://www.latus-harley-davidson.com...lamp-Kit-2.htm
i got my headlight from these guys.
mag10 is offline
post #5 of 6 (permalink) Old 07-07-2011, 02:13 PM
Thanks! Did you have to "engineer" the electrical input? In other words, since the Tbird has wiring to a single bulb, how did you wire it to both of the lights in the dual light assembly?
Also, did you notice better night vision after the conversion? Thanks again!
DocT is offline
post #6 of 6 (permalink) Old 07-07-2011, 10:13 PM
fairly easy, that dual light is intended have both bulbs on at the same time, so you have dual high and dual low beams, it is very bright (good thing). The HD dual came with a long pigtail and some weird HD plug on the end. I cut most of that off and cut off the plug end of the stock t-bird light (with some wire left in case I wanted to put it back on) I then put standard 'bullet' type connectors on the 3 wires. checked to make sure I got the high and low light right, taped it all up and plastic wire wrapped the whole thing so it looks nice and tidy. thats about it.
much better at night, like twice as good!
mag10 is offline
Anyone ever fit up dual headlights on a Thruxton? outlaw-x Air Cooled Twins Talk 22 09-04-2012 09:07 PM
I must find dual headlights. Rob 93ZR-1 Thunderbird Cruiser Chat 26 04-03-2010 11:54 PM
Rocket III Dual Headlights on a Speedmaster THRUXGIRL Maintenance & Workshop Talk 0 11-28-2004 08:30 PM
Ever seen Dual HeadLights on a TBIRD? 00wabbit Hinckley Classic Triples 5 08-22-2004 02:21 PM
Dual headlights re-wiring jvb Sprint Forum 5 04-01-2004 06:19 PM
