Another Loose Belt - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 3 (permalink) Old 06-24-2011, 10:44 PM Thread Starter
Another Loose Belt
2011 Storm 1,300 miles
The wife said she could hear a chirping noise while riding two up. I couldnít hear any noise when I rode it alone but I checked the belt and was able to move it well over an inch. I swear that the bike felt a little sloppy on tight very slow turns while slowly rolling on a very tiny bit of power as compared to when it was new. It just felt hard stay smooth on a tight turn.
I tightened the belt to where I can move it about Ĺ inch with ten pounds of force. This was a guess after practicing with a ten-pound weight. But the weight seems to make little difference because at the point you canít move the belt any more it seems that it would take way more then 10 pounds to move it any further. In other words the belt pretty much stays put from 10 to at least 25 pounds of force and moves VERY little even after 25 pounds. I left it at about a Ĺ inch because the ľ inch felt sooooo tight especially after coming off of adjusting dirt bike chains. I can always re-tighten but I do not know how I would tell if the belt was too tight and it would be very hard to slide the wheel forward. As compared to having the adjusters pull the wheel back.
On the test ride it felt easier to smoothly roll on small amounts of power in a tight slow turn and it felt like it had a little more snap with a blip of the throttle like the day I bought it. I swear I could feel a performance increase.
My bike was a demo with 130 miles on it. It came with the short pipes, black teardrop mirrors, the high flow air filter, re-mapping and black swing arm trim pieces. The swing arm pieces give it a very clean look hiding the axle and adjuster bolts. The down side was I had to remove the pipes to get the swing arm trim pieces off to get to the axle and adjuster bolts.
I think I got a pretty good deal on the bike, $12,500 with the full 2-year warranty. The dealer did not mention if the bike has ABS. I can see an ABS light along with the other cluster of lights but I do not know if it has ABS. I picked up the quick release sissy bar and I am waiting for the long haul rider and passenger seat which I am hoping is much more comfortable then the stock seats.
This bike is AWESOME and is a ball to ride especially through twisties and hills.
finglan is offline
post #2 of 3 (permalink) Old 06-24-2011, 11:20 PM
Main Motorcycle: 2010 Thunderbird SE
56Renegade's Avatar
If you have ABS there will be a ring on the left side of the wheels near the hub that has vanes so that the counters can detect if a wheel is locking up. They're about the size of a CD. My ABS light comes on when I start the 'Bird and goes off when I've traveled about 20 feet. I can't tell you if the long haul seat is better as my SE came with it. But I can tell you that I have no complaints about the seat. It feels good after two hours straight (my longest ride so far).
Hope this helps,
56R
56Renegade is offline
post #3 of 3 (permalink) Old 06-24-2011, 11:43 PM
Main Motorcycle: 2004 Speedmaster
marc hanna's Avatar
Manual belt tensioners can be bought quite cheap, they're not all that precise but they're better than you can do by feel.
Alternatively you get get a sonic tension meter. These are extremely precise, but they run about $1000! If anyone's in my area I'll tension their belt for free.
UNI pods, AI removed, de-baffled TORs, relocated battery, custom bobbed fender, custom wiring, etc
marc hanna is offline
Belt DruAde Thunderbird Cruiser Chat 2 04-10-2010 07:05 PM
Belt Drive Anyone? djmakm Air Cooled Twins Technical Talk 2 09-07-2008 01:22 AM
Belt drive for TBA? Brit26 Air Cooled Twins Talk 3 05-31-2006 09:42 PM
belt drives usbrit Air Cooled Twins Talk 0 11-28-2005 12:48 PM
Belt Drive Bushwhacker Hinckley Classic Triples 3 03-25-2005 09:44 PM
