backfire then engine dies (almost) - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 10 (permalink) Old 06-20-2011, 07:23 PM Thread Starter
Has anyone ever experienced this and it was NOT attributable to a loose map sensor hose? I was on a downhill returning home from a 2-3 hour ride and i'm going about 50 with very little throttle because of the downhill and i hear a back fire and the engine is no longer responding to throttle. I pull over and the engine is still running but barely and i hear another couple backfires as it's struggling to idle. So i shut the engine off and hit the restart button and all is back to normal and i ride home with not further issues, no engine light, nothing. Any ideas?
dazco is offline
post #2 of 10 (permalink) Old 06-21-2011, 12:37 AM
Main Motorcycle: Thunderbird SE A1
MickeyBoy's Avatar
Talking
Gremlins?
Dude Extraordinaire
MickeyBoy is offline
post #3 of 10 (permalink) Old 06-21-2011, 11:13 AM Thread Starter
Actually, yeah, probably. Or in other words a fluke maybe....a bit of water or dirt in the fuel or some such thing. I suppose it's possible. In 15000 miles this is the first hiccup of any kind.
dazco is offline
post #4 of 10 (permalink) Old 06-22-2011, 01:29 AM
Main Motorcycle: THUNDERBIRD
Other Motorcycle: HONDA VT750DC
Thats strange Daz. the onlythought that comes to mind is that it adapted to a lean situation.
linkdog is offline
post #5 of 10 (permalink) Old 06-22-2011, 01:57 AM Thread Starter
Could be....i had just come down from the top of the local mountain range rather quickly. The last several miles are particularly steep. I don't know that the bike adapts that fast tho. But it does make me wonder now that you mention it.
dazco is offline
post #6 of 10 (permalink) Old 06-22-2011, 02:04 AM
MickeyBoy's Avatar
Talking
If it was Big Bear, there should be no problem. I've done it four times and all I suffered was blown fork seals the first time I rode it.
Dude Extraordinaire
post #7 of 10 (permalink) Old 06-22-2011, 02:57 AM Thread Starter
No, but you're right...big bear or any mountain like that should be no problem normally. Just wondering if it could have adapted differently than normal. A fluke if you will.
dazco is offline
post #8 of 10 (permalink) Old 06-22-2011, 08:35 AM
MickeyBoy's Avatar
Talking
It actually sounds as if one of your injectors stuck open. More of an electrical glitch than a mechanical. Once you shut it down and re-fired the motor everything reset.
Dude Extraordinaire
post #9 of 10 (permalink) Old 06-22-2011, 11:41 PM
If you were running the original 203 stock tune than I'd say everythings normal
linkdog is offline
post #10 of 10 (permalink) Old 07-04-2011, 04:29 PM
Main Motorcycle: '10 Thunderbird, '12 RIII
Other Motorcycle: '05 Speedmaster
I had a similar situation when my bike only had a few hundred miles on her...it kept repeating itself, especially when coming to a stop...like at a red-light. A friend of mine recently had similar problems with his bike too, and found out that he had water in the line. A bottle of HEAT fixed the problem entirely.
Same exact thing occurred to my son's Speedmaster...
Probably not the same issue, but thought I'd share a similar problem.
DocT is offline
engine stalls or dies suddenly. help please? isabelle07 Air Cooled Twins Technical Talk 48 03-12-2014 08:20 PM
'97 speed triple 750 engine dies GazBowes T3 Sport / Touring Forum 22 04-02-2009 07:12 PM
Cold Engine - Dies when put in gear Adventurer≥ Hinckley Classic Triples 10 10-17-2008 11:29 PM
engine dies with choke pushed down.. janchen Club Cafe' 3 10-13-2008 11:30 PM
TBS ENGINE DIES keen Hinckley Classic Triples 4 02-11-2006 07:56 AM
