a question for those with Hogslayers... - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 10 (permalink) Old 05-31-2011, 09:09 PM Thread Starter
Main Motorcycle: 2010 Triumph Thunderbird
Other Motorcycle: Suzuki M50
My bird's at the dealership. I'm having the header pipes and my new hogslayers ceramic coated black. Service guy called me saying that they need to order 4 gaskets (2 small and 2 larger ones) to replace the ones between the header pipes and the new hogs. He said that they are wire mesh and when they removed them to take off the stock exhaust, they became frayed and will look like sh*t if they re-use them. He said the hogs didn't come with new header gaskets (I didn't look in the box as they were delivered direct to the dealer) Now I wait for the new gaskets to come in. Does this sound right? I did my homework on the Hogslayers ( I thought) and didn't see this one coming...
8trackpony is offline
post #2 of 10 (permalink) Old 05-31-2011, 10:16 PM
Main Motorcycle: 2010 Thunderbird 1600
oldgreybull's Avatar
Other Motorcycle: 2002 Suzuki Volusia
I watched the install video provided by BC and it says to, "carefully remove the pipes from the CAT as the gaskets will be re-used". That tells me no gaskets are provided with the hogslayers and they expect you to be able to use what's there.
Perhaps your pipes didn't come off as cleanly as they're supposed to.
I'm thinking of getting the hogslayers myself and will look forward to hearing how this works out and how long the delay will be. I guess one solution is to order gaskets up front so they're on hand when you install.
oldgreybull is offline
post #3 of 10 (permalink) Old 05-31-2011, 10:23 PM
Cars or motorcycles I've never had pipes come with gaskets.
Lantesh is offline
post #4 of 10 (permalink) Old 06-01-2011, 12:04 AM Thread Starter
Yes I watched the install video a few times too and just thought (as mentioned in the video) that the stock gaskets could be re-used. Better to have new ones I suppose. Hopefully they don't take too long to arrive. Pre-ordering your gaskets definitely seems like a good idea now...OGB I'll let you know how long it takes for them to arrive. Cheers!
post #5 of 10 (permalink) Old 06-01-2011, 10:15 AM
Agreed - however they are apparently needed for this install and BC does provide heat shields, clamps etc. which are also "extras". Apparently in BC's experience the gaskets remain intact and can be re-used without problems. In this case the dealer implies the gaskets are serviceable but cometically unacceptable.
I wonder if the tech doing the work was not aware that care was required to retain the gaskets, and there was an "O#$%" moment and frantic digging in the trash heap when he/she realized they were needed?!
post #6 of 10 (permalink) Old 06-06-2011, 01:04 AM
Main Motorcycle: '12 Bonneville T100 Black
Other Motorcycle: '09 Tiger 1050
Mine didn't come with extra gaskets. I was able to re-use the existing with no problems at all. Perhaps a gorilla handed tech worked on yours. Like a lot of things on bikes, you have to be careful when taking things off as to not "f" something up.
Daryl
'09 Tiger 1050 ABS
'10 Thunderbird 1600
TBirdDaryl is offline
post #7 of 10 (permalink) Old 06-10-2011, 03:50 AM Thread Starter
and I wait...and I wait...for these freakin' gaskets to arrive... The kicker is the service dept. told the ceramic coating company that there's no rush because of the wait on the gaskets! I found this out when I called for an ETA on the ceramic coating job! I asked the guys at the ceramic coating company to please get that done asap. (originally I had it all worked out to be completely done and back on the bike in a few days) I'm really looking forward to getting my 'bird back...When I do I'll tell you how I really feel...
post #8 of 10 (permalink) Old 06-19-2011, 07:41 PM
TBird Daryl39's Avatar
I agree with the other Daryl above. I installed my own Hogslayers and had no trouble sliding the old pipes out and the new ones in. The video was very clear on how to be careful taking the CAT box out. I would be very frank with your dealer - if THEY messed up YOUR gaskets then it is on THEM to get YOU new gaskets. Let the service manager yell at the tech that made the mistake and then the next Tbird in will get done right the first time. Don't let them charge you for it - if they made a mistake it's on them - you should in no way have to pay for their mistake - it's part of the price of doing business and they should understand that.
---Daryl
Don't sweat the petty things, and don't pet the sweaty things
TBird Daryl39 is offline
post #9 of 10 (permalink) Old 06-25-2011, 06:22 AM
Main Motorcycle: Thunderbird 1700 Big Bore
mad_angler's Avatar
if they have removed your header pipes you must have new gaskets of them where they meet the head, they are a crush type so one the headers have been removed they will leak i re fitted, as for the other two at the other end they can breakup when removed, i had to replace mine when i changed them .
Thunderbird 1700cc Big Bore - There's No Replacement For Displacement
mad_angler is offline
post #10 of 10 (permalink) Old 06-25-2011, 11:33 AM
Main Motorcycle: Triumph Thunderbird 1600
Baltothunder's Avatar
Other Motorcycle: '83 Honda Magna VF750C
When I removed my pipes, the gaskets stayed stuck with the silencers. Without some kind of puller or tool, its almost impossible to get them out of the pipes without destroying them.
2nd Officer Harbor Chapter #215 Southern Cruisers Riding Club
Never take for granted what you have been given, and what you have earned....
Baltothunder is offline
Do you have BC Hogslayers on your 'Bird?? 8trackpony Thunderbird Cruiser Chat 17 03-18-2011 05:47 AM
Hogslayers in BLACK 8trackpony Thunderbird Cruiser Chat 0 09-14-2010 10:29 PM
BC Hogslayers Corner Banger Thunderbird Cruiser Chat 16 06-21-2010 06:15 PM
exhaust pipe question and reserve tank question killian101 Air Cooled Twins Technical Talk 2 07-05-2008 04:50 PM
Ok…newbie question please no flames….reliability question... Qweevox Daytona Deliberations 5 03-28-2008 10:48 AM
