"chirp" under torque - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 13 (permalink) Old 05-15-2011, 07:46 PM Thread Starter
Main Motorcycle: My new '10 T'Bird
argyle's Avatar
Location: Where the Ozark mountains meet the Iowa cornfields
Other Motorcycle: '07 America
Extra Motorcycle: '88 Honda V-45 Magna
My bird has about 7,000 miles on it and recently I've begun to hear a sort of "chirp" when accelerating more than very mildly. I think the belt may need adjusting. Anyone else experienced this?
'07 America, AI removed, Hyde Bellmouth, long TORS, 125 mains
'10 Thunderbird, BB kit, long TORS
argyle is offline
post #2 of 13 (permalink) Old 05-15-2011, 08:31 PM
About 1/2 of us have and it is the belt alright, tho probably not the tension but the alignment. Wheel needs alignment, as when it's out even slightly so is the belt. Do NOT use the marks on the swingarm to align it. I did and it destroyed the belt in time. Triumph warrantied it only because i told them i used the manual and went by the marks. How are they going to argue that oine when thier own manual is wrong !
Anyways, It needs to be done with a triumph tool which is a rod that goes thru the axl and is used with the little square nubs on the swingarm to align it. Many dealers may not have this tool or even know of it because the bird is the first belted triumph. Thats what I found anyways, so if you bring it to a dealer ask them about the tool and make sure they have it. Many bikes were delivered with the alignment out which is why so many had the chirp.
dazco is offline
post #3 of 13 (permalink) Old 05-16-2011, 02:11 PM Thread Starter
argyle's Avatar
Thanks, dazco. I have to have a new rear tire put on - alignment of the rear wheel should be part of the re-installation process, shouldn't it?
argyle is offline
post #4 of 13 (permalink) Old 05-16-2011, 02:43 PM
I would hope so, but what i was pointing out is that dealers are incredibly clueless about many things and this is one of them. Unfortunately it's nearly impossible to own a bike and have them do all the maintenance w/o screwing up a good 1/2 the time. Thats why most of us had a chirp at one time or another. The mechanic who did my BB kit and installed the new warranty belt i had more confidence in because he is the USA triumph fleet manager, the guy who does all triumph's USA press bikes, IE: the bikes given out for mag reviews, demo truck, etc. So more than any dealer he is likely to know all this stuff. And sure enough he showed me the tool and explained all about the adjustment to a degree i doubt more than a few dealers understand. Thats why I suggested you ask them if they have the tool and show it to you. If they have the tool then they know what they are doing. But ask them to show you the ALIGNMENT tool, NOT the belt tension tool. that has nothing to do with the wheel alignment.
dazco is offline
post #5 of 13 (permalink) Old 05-17-2011, 01:15 PM
Main Motorcycle: 2010 Triumph Thunderbird
TBird Daryl39's Avatar
Good info - I have a Motorsport bike shop that I have all my non-warranty maintenance done at because I trust them about 300% more than the dealer, but I've wondered what to do when it comes time to replace the rear tire. I have 3,500 miles on the original and it's doing great but can definitely see signs of wear. Very subtle cupping - nothing like others have experienced and posted on other threads. I'll keep this thread handy to show the shop that does my tire and no tool, then they don't get to do the tire.
---Daryl
Don't sweat the petty things, and don't pet the sweaty things
TBird Daryl39 is offline
post #6 of 13 (permalink) Old 05-19-2011, 12:25 PM
Main Motorcycle: My 2010 Thunderbird
Extra Motorcycle: KLR 650
The chirp I had awhile back was most-definitely rear wheel alignment... took my dealer a bit to realize it, but at least the tech was diligent enough to keep on it till he figured out it wasn't the belt but the wheel on the swing arm. It's been perfect ever since.
"I don't want a pickle, just wanna ride on my motorsickle." ~ Arlo Guthrie
Narsisco Lopez is offline
post #7 of 13 (permalink) Old 05-20-2011, 02:45 AM
I had some horrible squealing that started at around 600 miles. I took the bike back to the dealer at about 900 miles, and the tech said the rear wheel was not perfectly straight. The squealing was the belt walking to one side of the pulley. I've put a little over a hundred on since he realigned the rear wheel, and it is now perfectly silent.
Lantesh is offline
post #8 of 13 (permalink) Old 08-06-2011, 07:14 PM
Main Motorcycle: 2012 Tiger Explorer
k12techman's Avatar
I've been fighting with the chirping noise on my 2010 Thunderbird for some time now. I have a bit over 12K miles on the bike and don't ever notice the chirping being a problem until I let the dealership touch the bike.
I've scoured the Internet to find anyone that's had the same problem and to read how they solved it. After spending the better part of all weekend for the past few weekends, I think I have it narrowed down to two things:
1. Belt tension
2. Wheel alignment
With the bike on the side stand, Triumph says that a 10lb force should deflect the belt between .20" and .27". MAN is that TIGHT. But, sure enough, if you don't put it under that tension, the belt chirps. I do wonder about the longevity of the front pulley and output shaft with the belt under that much tension. For what it's worth, setting the belt tension is actually the easy part of the whole process.
I put my bike up on a jack stand and get the bike perpendicular to the garage floor. Following the procedure outlined in the service manual, I loosen the axle nut but DON'T remove it. Then, I put the jack up a couple more pumps to make sure the bike's rear tire is off the floor. (If you ask me, there's no great place to use a jack on the Thunderbird. Sure do wish I had a whole bike lift). Now I loosen and remove the lock nuts from the adjustment slides at the very rear of the swing arm. I can now make the tension adjustment using the adjustment nuts that butt up against the very rear of the swing arm.
BUT, this ain't over just yet. Now you have to make sure that the wheel is aligned as well. There's been mention on several forums of a special tool that Triumph has to adjust the rear tire on the Thunderbird. Evidently it consists of a rod that goes through the axle and then matches up on the swing arm to somehow show the wheel is aligned. I have not been able to find this tool anywhere on the Internet and my dealer says Triumph won't sell it to individuals. As a matter of fact, they didn't want to show me the one they had very badly.
So, the next stop might be to simply measure how much thread is showing on both adjuster bolts and make sure they are even, right? Nope, not on my bike. Those adjuster bolts aren't the same length! As a matter of fact, there's a 3mm difference between them. So, you can't just measure thread left and think your wheel is aligned.
I got crazy with mine. I decided to measure from the center of the swing arm bolt to the center of the axle hole at the back. On the left side of the bike, this isn't too hard. On the right side, I had to remove the pulley cover and the coolant reservoir to see the bolt.
Once I could see both sides of the swing arm bolt, I measure on both sides and got it within about 0.3mm. Should be close enough. Once I confirmed that the wheel was aligned this way, I snugged things up and took it for a test run. No chirp, no noise.
So, I brought it back to the garage to get ready to put the other parts back on. Before I did that, though, I measured from the center of the axle hole to the rear of the swing arm to see if that measurement was the same on both sides. This way I don't ever have to take the damn pulley cover and reservoir loose again just to check wheel alignment. Sure enough (and as you'd expect), those measurements were equal.
So, I think I have the belt tension adjusted correctly and the wheel aligned. I even sprung for one of those little belt tension tools that lets you put exactly 10lbs. of force to the belt and measure it's deflection. Mine comes to just a hair over .25" of deflection. But, like I said before, that belt sure seems damn tight, IMO.
A couple of notes here:
Do NOT use the little "guides" on the sides of the frame to try and align the rear wheel. Those little guides and the groove in the adjuster are about as useful as **** on a bull.
Do NOT count on the bolts from the adjusters to be the same length. I did at first and couldn't get the wheel aligned. So, I finally decided to measure the bolts themselves from where the adjuster touches the axle to the end of the bolt. There were NOT the same length.
Do measure from the center of the swing arm bolt to the center of the axle bolt to get a good idea of whether or not the wheel is aligned. I figured the swing arm bolt and the axle have to be perfectly parallel, so they should be equally distant on both sides of the bike from the axle.
Do NOT trust that the dealership knows how to align the rear wheel of a Thunderbird. They told me that some belts just chirp and that all I need to do was buy louder pipes so I didn't hear it. I'm not against the louder pipes, but I don't want to just cover up a problem; I want it fixed.
Anybody see any flaws in my logic or what I did?
2012 Tiger Explorer - How about an adventure today?
k12techman is offline
post #9 of 13 (permalink) Old 04-11-2012, 01:50 PM
Main Motorcycle: 2010 T-Bird W/BB cams
Other Motorcycle: KLX-250
I haven't been on the site for awhile - swamped at work. Now that riding season is upon us that will change. Hey alot of great info on the belt alignment. I have had the chirp from time to time but hey, I would like to know if anyone has came up with a good way to lift the T-bird off the ground to change a rear tire or at least spin it to check how the belt is running. I was thinking about buying a shop crane???
trbird is offline
post #10 of 13 (permalink) Old 04-11-2012, 07:09 PM
A Pitbull lift works great on my TBird.
Daycruiser is offline
Belt "chirp"-or is it? thmoze Thunderbird Cruiser Chat 4 08-06-2011 07:12 PM
Travesty? Cool? Triumphs turned into "Choppers" and "Bobbers" S3 Street Rat Biker Hang-Out 46 07-14-2011 01:56 PM
What happened to "Torque", Triumph's magazine? eurochien Air Cooled Twins Talk 34 01-16-2009 04:45 PM
Does "Torque" magazine really exist? xardoz General RAT Discussion Forum 17 11-09-2007 01:29 AM
