Tire Wear-What to expect - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 24 (permalink) Old 05-09-2011, 12:15 AM
Main Motorcycle: 2010 Triumph Thunderbird
Originally Posted by Golfnut View Post
the tires are worn in the middle and are still in pretty good shape on the sides.
I'm wondering if that is a result of being low profile. Unlike a tire that has a significant sidewall the tire's sidewall on a Thunderbird can't flex, and therefore the tire will always have limited surface contact.
Lantesh is offline
post #12 of 24 (permalink) Old 05-09-2011, 01:28 AM
Main Motorcycle: THUNDERBIRD
Other Motorcycle: HONDA VT750DC
10,500 mi. so far,front to rear wearing fairly even mostly in the middle and getting thin. I'm staying with the Metz. Although thin these tires never give up and not always a sedate rider.
linkdog is offline
post #13 of 24 (permalink) Old 05-09-2011, 12:14 PM
Main Motorcycle: Trophy SE
Other Motorcycle: Honda CB900F 919
Extra Motorcycle: Honda CB750A Hondamatic
I am now on my fourth rear tire, second front.
I went with the metz the second time around, then was forced into a set of Bridgestones for the third rear and second front. The Bridgestone lasted a whole 5300 miles before it was time to change.
I am now running the bridgestone in the front (it seems to be a pretty solid tire up front) and a Dunlop dual-compound in the rear, which I am hoping will last longer than the Metz's did. I think I could get somewhere between 7k and 8k out of the Metz... both of my previous ones were changed out before their time, the first due to an upcoming long distance trip and the second due to a road hazard.
I will be happy to report on the progress of the Dunlop as time progresses.
Past Bikes:
2006 Suzuki Boulevard S50
Wells is offline
post #14 of 24 (permalink) Old 05-09-2011, 01:49 PM
Main Motorcycle: My new '10 T'Bird
argyle's Avatar
Location: Where the Ozark mountains meet the Iowa cornfields
Other Motorcycle: '07 America
Extra Motorcycle: '88 Honda V-45 Magna
Originally Posted by rod2625 View Post
For me the trick is to run them at Metzeler recommended tire pressure, i.e. 42 rear/ 40 ft.
Good tip. That is well above the pressure that Triumph recommends. I just passed 7k and my rear tire has turned into a slick.
'07 America, AI removed, Hyde Bellmouth, long TORS, 125 mains
'10 Thunderbird, BB kit, long TORS
argyle is offline
post #15 of 24 (permalink) Old 05-09-2011, 05:48 PM
Main Motorcycle: '12 Bonneville T100 Black
Other Motorcycle: '09 Tiger 1050
Originally Posted by TBirdDaryl View Post
Keep in mind there are a lot of factors involved such as riding style, load (solo, 2-up), etc... I'm not a very big guy (150 lbs), ride solo 95% of the time and ride "sedately" (to use dazco's term) 95% of the time. I just went over 3K on my T-Bird and the tires look great. I fully expect to get at least 10K out of them easily. My Tiger 1050 has 4600 miles on it and the tires (Michelin Pilots) on it look great too.
I had a Heritage Softail years ago and would get 14K or so out of the rear and 25K or so out of the rear.
FTR, I replace tires when they get to the wear bars so I'm not talking about wearing down to the point of having a slick.
The quoted reply was mine from May of last year. I'm now at 8400 miles and my OEM tires look great. I'll easily get 12K out of them, maybe more. For the record, I run them at the recommended pressures found on the frame and in the manual (36 and 38, if I recall correctly).
Daryl
'09 Tiger 1050 ABS
'10 Thunderbird 1600
TBirdDaryl is offline
post #16 of 24 (permalink) Old 05-18-2011, 12:51 AM
Main Motorcycle: 2016 Thruxton
andrew65's Avatar
Other Motorcycle: 2012 Street Triple R
I am on my third rear tire, got about 9-10k on each of the first two and 15k miles on the front before I changed it. Ran them all down to just getting smooth before changing them. Running about 40/42psi all stock metzelers, would try some avons if someone reported better mileage out of them.
andrew65 is offline
post #17 of 24 (permalink) Old 05-18-2011, 01:40 AM
Main Motorcycle: Triumph Thunderbird SE
Golfnut's Avatar
Other Motorcycle: 2012 Triumph Tiger 1050SE
Extra Motorcycle: Kawasaki Vulcan 900
Those mileage numbers are amazing to me. I wouldn't say I'm an overaggressive driver in the least. Actually, I do lots of commuting. I wonder if it may have something to do with the suspension settings?
Golfnut is offline
post #18 of 24 (permalink) Old 05-19-2011, 12:05 PM
andrew65's Avatar
I do a lot of commute miles too, been running the rear preload on 3 and I did run them down to smooth, maybe not a good idea but like to get the most I can out of them since they are pricey to replace.
andrew65 is offline
post #19 of 24 (permalink) Old 05-19-2011, 03:52 PM
My bike is on the factory suspension setting which is the softest setting, IIRC. Weight is another factor. I weigh 150 lbs soaking wet and ride solo 99% of the time as my wife isn't really into bikes much.
Daryl
'09 Tiger 1050 ABS
post #20 of 24 (permalink) Old 08-26-2011, 12:12 PM
TBird Daryl39's Avatar
I picked up this thread this morning as I am now shopping for my 1st replacement rear tire. The variance in reported mileage is, frankly, astonishing to me. Could there be a huge difference in road composition, different tire batches from the factory? I am a first time rider, the Tbird is my first bike, so this tire has been babied more than most. I don't mind nailing gears 1-4 in a straight line occasionally but I'm a bit sedate in tight corners. I hit wear bars at 5,300 miles. Looking at the front I'm not at all sure it will last until 10k. I'm meticulous about maintaining tire pressures, check them weekly and keep them 1lb higher than factory recommended. I ride solo 100% of the time and weigh 200lbs. So I'm with some of you guys looking for a tire that will give more mileage for straightaway riding. I'm not sport biking it in corners so I don't need the stickiest tire, but neither do I want a clodhopper. I see some of the heavier bikes like the vulcan Nomad, and Rocket III, Yamaha cruisers are running the Bridgestone...and it's $60 cheaper. Still haven't decided tho because other than mileage I've had zero problems with the Metz.
---Daryl
Don't sweat the petty things, and don't pet the sweaty things
TBird Daryl39 is offline
Tire Wear John21 T3 Sport / Touring Forum 6 09-28-2007 06:11 AM
Tire wear vis a vis tire sizes KaHOnas Sprint Forum 10 04-15-2007 05:18 AM
Tire wear... scott_spry Tiger Workshop (archive) 10 06-28-2006 05:11 PM
Tire wear... Jwilly Triumph SuperSports 9 03-01-2006 08:50 PM
What Tyre Wear Can I expect, & will it last Mutley Tiger Chat 6 06-18-2004 08:30 AM
