Oil Preference - Triumph Forum: Triumph Rat Motorcycle Forums
 4Likes
post #1 of 54 (permalink) Old 11-26-2009, 12:55 PM Thread Starter
Main Motorcycle: BB '10 Thunderbird
Send a message via Yahoo to AZfun
Oil Preference
I scanned the forum for threads on preferred oil but didn’t see anything (or missed it).
So, what oil brands rank high amongst Triumph riders (Mobil 1, Red Line, etc)?
My Harley Davidson neighbor swears by Amsoil and I personally like Royal Purple.
Any comparison stats or comments would be great!
AZfun is offline
post #2 of 54 (permalink) Old 11-26-2009, 01:38 PM
After reading about oil ad nausium both in oil threads at many forums and doing google research, i've come to the conclusion any good oil is going to be as good as the next if you change it VERY often. The shear factor in bikes with shared oil between case and gear box is what kills oil much quicker than in a car. It's said 3k is the point at which it loses a large portion of it's lubrication properties. So may say change it every 3k instead of worrying about oil types. Thats from what i've read seems to be the overwhelming general consensus.
That said, i think no one would disagree that you can't go wrong with M1 bike oil or amsoil. But as far as which bike oil has been the #1 most touted overall in my searches i'd have to say it's probably motul. I've never heard a bad thing said about it, only real positive things. It was also recommended to me by triumph a mechanic i probably respect more than any other triumph mechanic. So that would be my choice.
dazco is offline
post #3 of 54 (permalink) Old 11-26-2009, 09:57 PM
Main Motorcycle: Hmmm? Tough one.
OKCTriple's Avatar
Mobil 1 Racing 4T
https://www.mobiloil.com/USA-English...4T_10W-40.aspx
Dazco is right but my oil of choice for all my bikes (air or watercooled) is mobil1 R4T.
Other bikes: 2005 Thruxton with 904 Wiseco big bore kit, BC stage one cams, CR carbs & BC Predators, 2010 Husaberg FE390, 2010 Triumph Thunderbird 1700, 2009 Kawaskai ZX-6R, 2011 Kawasaki Ninja 1000.
OKCTriple is offline
post #4 of 54 (permalink) Old 11-26-2009, 10:39 PM
Main Motorcycle: 2010 Thunderbird
I also went the M1 4T route. There was a noticeable difference in noise and shifting when I changed out the break-in blend. Mobil1, Amsoil, Motul, Lucas, Royal Purple...all good stuff. Go with what you can get and make sure its API SH+ and JASO MA compliant. BTW, the "MA" is VERY important here, it means that the oil has been tested and approved for wet clutch applications in motorcycles. If it's not JASO MA, you're asking for problems so be careful with that. NEVER NEVER NEVER run automobile oil in a motorcycle with a wet clutch.
Here's a few (use this term loosely for some of these) "studies"...
http://www.hdtalking.com/oil/1032-4_...st_begins.html
http://neptune.spacebears.com/cars/stories/mobil1.html
http://neptune.spacebears.com/cars/stories/amsoil.html
And there's a few thousand links out there showing the Amsoil propaganda testing. Easy to find and think what you want about them. I would prefer the tests were funded and presented by someone other than Amsoil if you know what I mean.
31712 is offline
post #5 of 54 (permalink) Old 11-26-2009, 11:35 PM
Main Motorcycle: 2010 Triumph Thunderbird
robertrichhart's Avatar
Other Motorcycle: 2012 Kawasaki Ninja
Thumbs up
Ditto on the Mobil 1 Racing 4T... It's worked well in my bikes...
robertrichhart is offline
post #6 of 54 (permalink) Old 11-28-2009, 09:42 PM Thread Starter
Dazco...Motul, I think I'll switch from Royal Purple!
Thanks All for your input....
AZfun is offline
post #7 of 54 (permalink) Old 11-30-2009, 06:34 PM
Supernova
Main Motorcycle: 2012 Tiger 800XC
Motorcyclist
propforward's Avatar
Other Motorcycle: 2007 Bonneville, ST1300
Here is a report that is a good read:
https://www.amsoil.com/lit/G-2156.pdf
I have always used Mobil 1 - 20W50 in my bikes whenever possible (for the higher shear resistance). I certainly wouldn't have any problem using other brands like Amsoil.
Well, everything seems to be in order then.
propforward is offline
post #8 of 54 (permalink) Old 12-15-2009, 11:47 PM Thread Starter
I found out break-in oil for my Thunderbird is MOTUL 3000 4T 10W40.
Afterward, the dealer recommends 15W50 Mobil synthetic.
I may stick with Motul....
AZfun is offline
post #9 of 54 (permalink) Old 10-21-2010, 02:36 PM
Newbie
Main Motorcycle: T.Bird
Hi as far as I'm aware Triumph have always recommended Mobil1 to be used in their motorcycles, but they have now done a deal with Castrol see link below>
http://www.castrolmoto.com/en/oem/triumph.php
Haydn71 is offline
post #10 of 54 (permalink) Old 10-21-2010, 02:44 PM
Main Motorcycle: '09 Sprint ST
braindead0's Avatar
Rotella in all my vehicles.
03tbirdgo likes this.
'09 Bonny SE, '09 Sprint ST
braindead0 is offline
Oil Preference? sjhill9859 Street Triple Forum 15 05-09-2009 10:10 PM
do you have a preference for a certain brand of gas? keithk Air Cooled Twins Technical Talk 17 09-25-2008 11:35 PM
Tire preference Topher Air Cooled Twins Technical Talk 32 03-29-2007 11:56 PM
Riding Preference bruiser06 Speed Triple Forum 20 10-09-2006 03:02 AM
Tyre preference ? JohnRimmer Daytona Deliberations 15 08-18-2004 12:17 PM
