Hi what is either the correct or optimal lever arm position on these bikes, mine being the T595?
Mine was fixed at around 11 O’clock but I have since taken it off to clean, grease, and fit new rubber seals to the ball joints. Also looking at an additional bush to pick up the slack at the gear-pedal/foot-peg ‘joint.’
So, back on as was...or adjust the bar between the ball joints and fit the gear lever arm differently?
