Hi Rusty
Oil Thread-that is a big can of worms that you have opened.
Looking at the Golden Film series of oils by Morris.
Firtsly the viscosity rating- the first number is the cold viscosity rating, the second is the hot viscosity rating.
While the cold rating can be varied within small margins- 10/50, 15/50 etc.
The second hot number can be considered a non variable, it is generally considered that any oil you choose should retain this rating. Our old air cooled engines run clearances and tollerances greater than modern engines, the thicker 50 rating accounts for this in multi grade oils. (Monogrades are a different subject).
The Golden film series is a low detergent oil. It does not have the additives that collect the combustion blow by carbon particles and wear particles and hold them in suspension. Instead, low detergent oil alows these particles to drop out of the oil and form a thick sludge at the bottom of the oil tank and in the crankshaft sludge trap.
This sounds bad, but it in fact the way our bikes were designed to work, we have no effective oil filters so the sludge effectively prevents these particles from being recirculated around the engine. This does mean that during oil changes the oil tank should be cleaned out and the sludge trap requires cleaning at regular intervals. (Requires complete engine stripdown)
However there is an alternative:
High detergent oils, as used in modern engines - these keep the combustion/wear particles in suspension in the oil, they form hardly any sludge, the oil tank stays cleaner and the sludge trap fills much more slowly. The downside is that these combustion particles keep getting recirculated around the engine, which is not desirable. Many owners that use high detergent oils fit after market oil filters to their bikes, these remove the undesirable combustion particles from the oil.
I think it is fair to say that most owners here use modern high detergent oils and an after market filter.
I will summarise the choices:
Low detergent oil, no filter, higher maintenance.
High detergent oil , aftermarket filter fitted, less maintenance.
One last thing, modern car oils have friction modifiers that play havoc with our wet clutches, an oil designed specifically for motorcycles oil is required.
Any oil you buy today will be a much better quality than the oils available when your bike was built.
Regards
Peg.
