I put the TORs on my otherwise stock Legend -00.
A/F screws are out about 3 turns and when it is warm it answers the throttle good, but the right hand side cylinder does not get as hot as the other two, it takes a while. I will sync the carbs, but it runs good.
I drove it with the other mufflers then the cylinders where equally hot, since I switched to TOR´s and rode it it was 3 days, so I do not think the carbs are fouled.
Could it be that the A/F screw on the right cylinder isn´t exactly as the other two?
Think it´s too soon to pull the new plugs to check, just wanna know if it is something to worry about.
Nothing yet, the links you provided does not work.
I talked to a local Triumph dealer and I am going to let them adjust the valves and sync the carburettors and then put in larger mains and adjust the mixture screws with a gas analyser, all this will no cost more than about 300$.
When it comes to TOR´s and otherwise stock airfilter etc, they usually put in 102,5 mains and 3 turns on the mixture screws, according to them they run fine after that.
