1 - 8 of 8 Posts
2021 Trident 660
I have a brand new 660, and if i stop fairly fast, pull in the clutch, then after coming to a complete stop, the bike will not go into first gear... it can got into 2nd, - 6th and back down, but not N and first
I have spoken to the service dept. and they asked "is it a new bike then yes, they can do that...." - i just have to take off in 2nd.
Is this a normal thing, or just a triumph normal run-in issue?
I stopped being able to find neutral on mine. Solution was to adjust clutch lever so it pulled the cable a bit further.
2021 Trident 660
Thanks i get that done on its first service...
Are you downshifting while you are coming to a stop or are you coming to a full stop and then trying to shift through the gears to first.
2018 Triumph Street Triple RS
Motorcycle transmissions are kinda finicky. If you are stopped, you might not be able to shift through the gears cleanly. Sometimes it just won't do it without letting off the clutch a bit then pulling it in again. Also, rolling the bike with your feet can help.
Ideally, you'd downshift while you are slowing down to avoid this problem. Does your bike shift smoothly and easily if you downshift while slowing to a stop? If so, you might just be noticing the finicky nature of motorcycle transmissions. They prefer to be moving when shifting through the gears.
Have you tried letting go of lever then pressing it again and then push the shifter? Whenever this happens to me I do this simple thing and 1st slips in first try.
1 - 8 of 8 Posts
