Greetings!
I'm wiring an '01 T100 from scratch, still using the stock ICU and want to make sure it functions properly. This is going on a bare bones bike with no accessories, side stand switch, clutch switch, neutral switch, etc., only the essentials to run.
Out of 9 wires on the ICU, I've identified the ones that lead to the TPS on the carbs, the leads from the pick-up coil and to the ignition coil, so that's 6 wires. The remaining 3 look like they can be grounded, does that sound correct?
I'm using the Haynes manual as a reference… it lists the 9 ICU wires like this:
2- (to #2 on HT coil)
10- (to ground)
8- (to 1 on HT coil)
5- (to #2 leads on pick-up coil & TPS)
6- (to #1 on pick-up coil)
9- (to clutch switch)
1- (to #1 on pick-up coil & #3 on side stand switch)
17- (to #1 on TPS)
4- (to #3 on TPS)
I can try and add a pic of the manual later if needed.
Thanks a ton for your help!
Cheers
10- (to ground)
17- (to #1 on TPS)
4- (to #3 on TPS)
Cheers
