1 - 3 of 3 Posts
I am about to start wiring up a T140E 1978 model [early models were built using T140V components for the period except sold with MK 11 Carbs] Positive earth and points
Took the opportunity in gathering parts and decided to use a Regulator Rectifier & 5 Way Male Plug Fr Honda CB250 CBR400 CBR600 CBR900 1100XX - as recommended on this site by Stuart a few months ago. Aim to fit it on the tray next to the coils.
But before I start wiring I need to determine if I have single or three phase alternator model - can I use an Ohms test on the three leads to find out.
Hi Bill,
Can you look in the inside circumference of the stator? You can see the ends of the coil cores - single-phase has six, three-phase has nine.
Or can you find the 5-figure number on the stator? 47252 would be a 'low-output' (10.5A @ 5,000 rpm) 3-phase, 47244 would be a 'high-output' (14.5A @ 5,000 rpm).
An Ohms test might work, if we knew what the values were ...
Fwiw, it'd be quite surprising to find a 3-wire single-phase stator on a '78; Lucas didn't supply 'em after sometime in '68 or '69, so a p.o. would've had to have fitted it.
Hth.
1 - 3 of 3 Posts
