Wiseco only lists the STANDARD BORE high compression pistons through 2010 models?
What changed? Triumph appears to list the same part numbers before and after 2010.
Its probably the last time they updated their listing
My first thought but then I noticed they continue to update the listings for the 92mm pistons. I'll give them a call and see what's up. It may be a clearance issue in some part of the combustion chamber.
