Are you riding by construction sites with bare legs?
you must be a cutie...
ok, I'll actually try to help, even tho your somewhat vague question invites rumination on the possible source of said whistling....
some helmets whistle, and the stock exhaust system can make a whistling sound at times.
give us another clue?
G
can be from the primary, it's a gear primary so it will whistle, also the carbs can make a whistling sound through the stock airbox. I'm guessing you have stock/quiet exhaust?
get some loud exhaust and an airbox elim kit and you'll be whistling!
Simo, when you ditch that airbox for a couple of K&N filters, that whistling sound will be gone & you'll think you've got a shop vac under your arse... :roflmoa2:
Scared the begeezers out of myself the first time I hit 4000rpm after my airbox mods.
A forum community dedicated to Triumph Motorcycle owners and enthusiasts. Come join the discussion about performance, racing, cafe racers, bobbers, riding, modifications, troubleshooting, maintenance, and more!
