Can I use an S4 sub-frame to mate with my TT600?
I checked the damage on my bike last night, and it's going to the shop later this week to get the main-frame looked at.
I tweaked the rear sub-frame pretty good when I laid the bike down, but thankfully, the plastics are in good shape and will look as good as new with some paint and some sanding.
The only plastic I need is probably the piece that goes on top of the 2 side pieces.
Are S4 plastics also compatible with the TT600?
I tried searching but couldn't come up with anything.
Best regards,
Jonathan
My initial thought was yes, but Bike Bandit's part numbers are different, so it's probably a no unless someone confirms otherwise.
I do have an S4 subframe you can have if you want it for minimal cost plus postage to the US.
Sweet, let me call up the local dealer and see if they can tell me... I'll definitely grab that subframe off you if it works out.
Thanks!
- Jonathan
