What is this part?
Looks like its been squashed. Can it be "fixed" or do I need to replace it?
What does it do? Does it even need to be fixed?
IMG_20200204_160212_0.jpg IMG_20200204_160244_1.jpg IMG_20200204_160426_9.jpg IMG_20200204_160444_1.jpg IMG_20200204_160500_9.jpg
This is the bottom of the riser? It could be a rubber grommet. You wouldn’t expect metal on metal at this juncture. Is there any front to back play in the handle bars?
It is an anti vibration rubber that has been well over tightened
Possible that someone may have had the handlebars off and on reinstallation, failed to put the lower "cup" in place.
Tightening the bolt without it would collapse the upper and lower rubber bushes.
Pic from top shows proper install (Has JBQ spacers)
Pic from bottom shows "cup" in place.
Also, there should be a little play in the bars . That's why there's rubber bushes in there, to absorb vibrations.
718120
718121
