1 - 1 of 1 Posts
Click Here to shop MotoSport.com for brakes and brake accessories for your Motorcycle!!!
Yana Shiki Left & Right Front Rotor Combo
-Full Floating Discs Design.
-Special Contour Disc - optimizes pad contact and performance
-Premium Japanese induction hardened stainless steel (410-DB).
-Laser cut for perfection and accuracy.
-Diamond ground finish.
-Light weight performance upgrade to OEM discs.
-Can be used with ANY type of brake pads.
MotoSport.com Price $379.99
<span style="color: #000000;">Brembo RCS 19 Brake Master Cylinder
<span style="color: #000000;">-Adjustable Pivot Distance - the rider can set the brake lever pivot point at one of two distances, 18 or 20mm, simply by turning a roller cam located on the front of the lever clevis.
<span style="color: #000000;">-Brake Light Switch - a housing has been included specifically to accept the mechanical switch of a brake light circuit, when the 19 RCS is set up for street use.
<span style="color: #000000;">-Forged Folding Brake Lever - limits damage in the event of a crash.
<span style="color: #000000;">-Inline Lever Span Adjuster - moved inline with lever to ease install of remote adjuster.
<span style="color: #000000;">-Lever Return Springs - 2 high load springs are used to ensure that the contact face and pushrod remain permanently engaged ultimately prolonging the life of the unit.
<span style="color: #000000;">-May require modification or replacement of stock brake fluid reservoir.
<span style="color: #000000;">-Requires 10MM X 1.00 banjo bolt.
<span style="color: #ff0000;">MotoSport.com Price $364.99
<span style="color: #000000;">Galfer Brake And Clutch Line Kit
<span style="color: #000000;">-Galfer has been leading the motorcycle industry by consistently making performance products that withstand the rigors and abuse of racing and aggressive riding.
<span style="color: #000000;">-Galfer brake and clutch lines are constructed from stainless steel with a clear PVC coating to avoid flexing for maximum stopping power.
<span style="color: #000000;">-Galfer built their line kit to be complete with lines, fittings and banjo bolts for complete and easy installation.
<span style="color: #000000;">-Stainless steel lines allow the rider to have maximum feel while reducing overall effort.
-Included: Front brake line, Rear brake line, and Clutch line.
<span style="color: #ff0000;">MotoSport.com Price $279.99
</span></span></span></span></span></span></span></span></span></span></span></span></span></span></span></span>
1 - 1 of 1 Posts
