1 - 20 of 27 Posts
09' Sprint NON ABS. Just got the left fairing off to check fasteners, etc. and install a radiator grille.
Part found on top of engine case near lower connection of coolant hose. It had been there since delivery, obvious debris/witness marks were evident that indicate same.
Looks like some kind of plastic spacer. 3/4 inch around, 1/4 inch hole in center and a groove in one spot on the exterior radius...i looked around, nothing looks loose, have no clue. Hopefully pic loads below...
Thats a referencing ring for your indexing array, that is.
If you don't have a discombobulator fitted it won't be a problem.
Looks like someone took their pillion grab handle off and didn't notice what else came off with the bolts.
There should be 4 of them to insulate each bolt and the handle from exhaust heat
Then again, I have seen a very similar one on the oscillating centrifugal combustion defeator...
You guys are all wet. That's the cushion for the chrome muffler bearing.
It's either the stock exhaust restrictor or the spacer for the grab bar...:)
My guess is it's the grab bar spacer.
Sent from my iPhone;)
Discussion Starter · #12 ·
Sussurf and Bill,
Thanks. All the grab handle spacers are in place. One got dropped during assembly it seems.
I found a few hose clamps barely tight enough while checking things there. Was worth the effort to poke around. Everything else looked fine and fairings went back on w/o issues.
You sure it's not it's not off the flux capacitor?
No it's a Naquida storage device, handle that very carefully and do not expose to any electromagnet field. :eek:
DaveM:rolleyes:
No no no, that's the die for the wire stretcher.
OMG....Y'all are a Trip!!!! Hahahahahahahaha
We are a very technical group and are always on call to help others.
The one thing this thread DOES teach is that most of us here have a good - possibly slightly warped sense of humor.:laughhard:thumbsup
Ya know, It looks to me to resemble the flow restrictor on a bottle of blinker fluid.
Have you changed your Halogen Gel this season?
1 - 20 of 27 Posts
