One thing that hasn't been mentioned, is that when you you remove the SAIS system, it leaves the electrical connection to the ECM open causing the check engine light to come on and stay on. The simple fix is to close this loop, which tells the ECM it's working. Bella Corse- bellacorse.com- offers a $20 loop closer easily installed. And you do not have to completely remove the whole system ( all the hoses and such) if you don't want to. You may find a similar item from others vendors.
Air Injection Solenoid Bypass Plug for Triumph
$19.99
Use this simple plug-n-play device when removing the Secondary Air Injection System on a 2009-2016 Triumph 865cc twin. Keeps Check Engine light from illuminating due to removal of SAIS.
